Gazebo AI Logic and Scripting
I'm new to Gazebo and really want to use it. However I'm overwhelmed with learning this API and all the tools that go into it. I've been following the tutorials for the XML scripting which is great but I've hit a wall in learning Gazebo and I do not know what to look into next.
My goal is to use Gazebo to create a multi-agent system and test out different coordination methods. Gazebo seems great for that. But I do not know how to script the models in the simulation. So for terseness I'll ask what I really want to know and hopefully someone can help.
To me and correct me if I'm wrong, Gazebo allows for physicals based simulations of agents / modules / robots of which are scripted and do computations outside of the Gazebo simulation but can be scripted to "tick" in simulation spaces?
I'm really interested in Gazebo I just don't know where to find more information on model scripting and I'm getting hung up in the beginner tutorials when I need more advanced information.
I would really appreciate any advice, resources, recommendations, or suggestions.
Thank you for your time.
Asked by clearwater on 2021-05-20 14:29:29 UTC
In my opinion, most common use case is Gazebo combined with ROS. Since they share common history in development, they are quite tightly connected and they work together well.
In general, Gazebo is used for defining the physics, models and some base functionality (via Gazebo plugins written in C++). Then, ROS is used for most of I/O, data processing, logic, agent planning/control, etc. In ROS you can use both C++ and Python, just pick what you prefer. I would discourage you from trying to use Gazebo plugins for create graphs or high level control. Plugins are meant to be used more for low-level, regular and quickly processed tasks (joint regulation, collision detection, sensors, ...). For example graphs can be really easily done by already existing tools like rqt_graph and others. ROS has its own logging mechanism and I could continue.
Try to check out some existing projects which use both ROS and Gazebo plugins to achieve the goal and get inspired by the structure.
This is probably not a complete answer, but I hope it will clear some things for you.
Asked by m.bahno on 2021-05-27 02:40:23 UTC
