gazebo not opening when using model://
ROS Noetic Gazebo doesnt open when I use the sdf:
<?xml version="1.0"?>
<sdf version="1.4">
<world name="myworld">
<uri> model://sun </uri>
<uri> model://ground_plane </uri>
<uri> model://cabinet </uri>
<pose>12 13 0 0 0 0</pose>
<uri> model://postbox </uri>
<pose>15 -10 0 0 0 0 </pose>
</world>
It works when I comment the cabinet and postbox model
<sdf version="1.4">
</world>
Launch file:
<launch>
<arg name="world" default="empty" />
<arg name="paused" default="false" />
<arg name="use_sim_time" default="true" />
<arg name="gui" default="true" />
<arg name="headless" default="false" />
<arg name="debug" default="false" />
<arg name="world_name" value="$(find obot_gazebo)/worlds/obot.world"/>
<arg name="paused" value="$(arg paused)" />
<arg name="use_sim_time" value="$(arg use_sim_time)" />
<arg name="gui" value="$(arg gui)" />
<arg name="headless" value="$(arg headless)" />
<arg name="debug" value="$(arg debug)" />
<param name="robot_description" command="$(find xacro)/xacro '$(find obot_description)/urdf/obot.xacro'" />
<node name="obot_spawn" pkg="gazebo_ros" type="spawn_model" output="screen" args="-urdf -param robot_description -model obot" />
<include file="$(find obot_control)/launch/obot_control.launch" />
</launch>
Command line output:
[ WARN] [1621663016.642603789]: link 'caster_wheel' material 'red' undefined.
[ WARN] [1621663016.643914257]: link 'caster_wheel' material 'red' undefined.
[ WARN] [1621663016.644428765]: The root link chassis has an inertia specified in the URDF, but KDL does not support a root link with an inertia. As a workaround, you can add an extra dummy link to your URDF.
[INFO] [1621663016.927299, 0.000000]: Controller Spawner: Waiting for service controller_manager/load_controller
[INFO] [1621663016.950044, 0.000000]: Loading model XML from ros parameter robot_description
[INFO] [1621663016.954453, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[ INFO] [1621663017.083933641]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1621663017.086121922]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1621663017.188760220]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1621663017.190537705]: waitForService: Service [/gazebo_gui/set_physics_properties] has not been advertised, waiting...
^C[robot_state_publisher-6] killing on exit
[obot/controller_spawner-5] killing on exit
[obot_spawn-4] killing on exit
[gazebo_gui-3] killing on exit
[gazebo-2] killing on exit
[WARN] [1621663045.381504, 0.000000]: Controller Spawner couldn't find the expected controller_manager ROS interface.
File "/opt/ros/noetic/lib/gazebo_ros/spawn_model", line 239, in <module>
exit_code = sm.run()
File "/opt/ros/noetic/lib/gazebo_ros/spawn_model", line 183, in run
success = gazebo_interface.spawn_urdf_model_client(self.args.model, model_xml, self.args.robot_namespace,
File "/opt/ros/noetic/lib/python3/dist-packages/gazebo_ros/gazebo_interface.py", line 28, in spawn_urdf_model_client
rospy.wait_for_service(gazebo_namespace+'/spawn_urdf_model')
File "/opt/ros/noetic/lib/python3/dist-packages/rospy/impl/tcpros_service.py", line 166, in wait_for_service
raise ROSInterruptException("rospy shutdown")
rospy.exceptions.ROSInterruptException: rospy shutdown
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
command line output of: gazebo --verbose obot.world
Gazebo multi-robot simulator, version 11.5.1
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.29.67
[Wrn] [ModelDatabase.cc:340] Getting models from[http://models.gazebosim.org/]. This may take a few seconds.
Asked by orensaldanha on 2021-05-21 04:41:15 UTC
Any useful output from the command?
Asked by Jose Luis Rivero on 2021-05-21 10:15:51 UTC
I have added the command line output to the question
Asked by orensaldanha on 2021-05-22 01:00:33 UTC
don't see anything useful. What happen if your run gazebo --verbose ?
Asked by Jose Luis Rivero on 2021-05-25 14:15:41 UTC
Same issue when I run gazebo with just the world file
Asked by orensaldanha on 2021-05-25 19:55:17 UTC
could you please add the output of plain gazebo --verbose to the issue?
Asked by Jose Luis Rivero on 2021-05-28 07:09:53 UTC
I have added the output
Asked by orensaldanha on 2021-05-28 07:40:48 UTC
I checked the turtlebot3 simulations, I couldnt launch the turtlebot3_house as well. So I decided to reinstall ros and gazebo. Its working now.
Asked by orensaldanha on 2021-06-02 11:23:21 UTC
