Gazebo's block laser plugin not printing out to a scan topic when gpu rays are used
I am trying to get a point cloud from gazebo's block laser plugin but I also have to use gpu rays since I need the rays to be able to pass through "glass". I cannot remove the collision tags of the glass for my application. Removing the visual tag is fine so I have done this and attempted to switch to gpu rays. The gpu rays appear in gazebo but they do not output to a topic. I have also tried the non-block gpu laser plugin (libgazeborosgpu_laser.so) but this flattens out all the detected points as a scan on two dimensions.
Here is the gpu plugin excerpt from the robot's urdf:
<sensor name="block_lidar" type="gpu_ray">
<pose>0.0 0.0 0.0 0.0 0.0 0.0</pose>
<ray>
<scan>
<horizontal>
<samples>30</samples>
<resolution>1</resolution>
<min_angle>-0.614356</min_angle>
<max_angle>0.614356</max_angle>
</horizontal>
<vertical>
</vertical>
</scan>
<range>
<min>0.05</min>
<max>90.0</max>
</range>
</ray>
<plugin name="lidar_plugin" filename="libgazebo_ros_gpu_block_laser.so">
<gaussianNoise>0.00</gaussianNoise>
<alwaysOn>true</alwaysOn>
<updateRate>20</updateRate>
<topicName>/daedalus/laser_scan_${prefix}</topicName>
<frameName>anchor_${prefix}</frameName>
<always_on>true</always_on>
<update_rate>10.0</update_rate>
And here is the non-block plugin excerpt:
<sensor type="gpu_ray" name="hokuyo">
<pose>0 0 0 0 0 1</pose>
<update_rate>10</update_rate>
<ray>
<scan>
<horizontal>
</horizontal>
<vertical>
</vertical>
</scan>
<range>
<min>0.05</min>
<max>90.0</max>
<resolution>0.01</resolution>
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.01</stddev>
</noise>
</ray>
<plugin name="gazebo_laser" filename="libgazebo_ros_gpu_laser.so">
<topicName>/daedalus/laser/scan_${prefix}</topicName>
I am using ros noetic, gazebo 11.3.0 running on Ubuntu 20.04 and my graphics card is an Nvidia Geforce 940mx with driver version 450.119.03. I would really appreciate any advice on how to get the gpu block laser printing to it's topic or how to get the expected 3D laser scan from the non-block laser plugin.
Asked by kedus42 on 2021-06-15 03:43:02 UTC
