Failures when launching qualification worlds
asked 2013-05-07 20:06:52 -0600
gerkey gravatar image
Extracted from question 2665
When using roslaunch atlas_utils qual_task_x.launch to launch the simulator, you have to launch it 4-5 times before the simulator actually launches and runs alright. There are a number of issues that happen here.
  1. The simulator starts and gets stuck displaying no timing or anything on the window. Just a grey window.
  2. The simulator starts and then writes to the log file and never displays a window.
  3. The simulator starts and does not write to the log file, does not show a window, and yet thinks that it has fully started and is running.
answered 2013-05-07 20:11:34 -0600
Your situation 1 (grey window) sounds like this known bug. A workaround for that situation is start another instance of gzclient in parallel. Don't close the non-functional gzclient window (you can minimize it).
Your situations 2 and 3 are new to me. My first guess is that there's a problem with your GPU driver configuration. What kind of graphics card are you using? Can you provide console output from the terminal where you ran roslaunch and encountered these situations?
I was running an Intel Card. Now I have switched to an NVIDIA card just now and have not had the problem yet. Need more time to test it out. The window seems to display each time now that I switched graphics cards.
aqiruse gravatar imageaqiruse ( 2013-05-10 15:35:27 -0600 )edit
I am sorry for the mistake. The computer I am using advertises an NVIDIA card in it. I thought they meant the primary graphics card was an NVIDIA. What they meant, and did not advertise, is that while yes it does have an NVIDIA card in it, the primary two adapters are NOT NVIDIA. They are Intel. Sorry for the mistake on my part.
aqiruse gravatar imageaqiruse ( 2013-05-10 15:47:25 -0600 )edit
Asked: 2013-05-07 20:06:52 -0600
Seen: 133 times
Last updated: May 07 '13
