Is libcuda required to run Ignition?
Do you need to have libcuda installed and running on a GPU-based machine to use Ignition? I'm getting an error that says "libcuda" could not be found in my Ignition Dome / ROS Melodic application; yet the simulation and GUI still loads.
Asked by jer on 2021-07-19 15:41:07 UTC
I don't think you need CUDA. Is the simulation not running at all? Can you paste the error logs?
Asked by azeey on 2021-08-23 11:10:01 UTC
