Where does my URDF for the plugins?
When I include a plugin in my URDF
or xacro
file in between the <plugin>
and <\plugin>
tags, where does it find the plugin from?
If I have a ROS package with plugins built from source as well as installed via apt-get
and want to use the ROS package installed from source (maybe because it contains my custom changes), how should I tell my URDF
or xacro
file to look for the plugin inside the package built from source and not the one installed via apt-get
Asked by HeatWaves on 2021-07-28 04:53:02 UTC
hello, you have to install your custom ROS package and source them. After beeing sourced, all ros related scripts should be able to find your custom plugins.
Asked by Clément Rolinat on 2021-07-28 07:17:57 UTC
