Could not determine the type for the passed topic
I am trying to make a ray sensor type. I am using ros dashing and gazebo 9. i followed the instructions here.
<?xml version="1.0" ?> <sdf version="1.5"> <model name="foggy_lidar_n1"> <link name="link"> <inertial> <pose>0 0 0 0 0 0</pose> <mass>0.19</mass> <inertia> <ixx>4.15e-6</ixx> <ixy>0</ixy> <ixz>0</ixz> <iyy>2.407e-6</iyy> <iyz>0</iyz> <izz>2.407e-6</izz> </inertia> </inertial> <visual name="visual"> <geometry> <box> <size>0.02 0.05 0.05</size> </box> </geometry> </visual> <sensor name="laser" type="ray"> <pose>0 0 0 0 1.51 0</pose> <always_on>1</always_on> <update_rate>30</update_rate> <visualize>true</visualize> <ray> <scan> <horizontal> <samples>512</samples> <resolution>1</resolution> <min_angle>-3.14</min_angle> <max_angle>3.14</max_angle> </horizontal> </scan> <range> <min>0.06</min> <max>15</max> <resolution>0.05</resolution> </range> <noise> <type>gaussian</type> <mean>0.0</mean> <stddev>0.01</stddev> </noise> </ray> <plugin name="laser" filename="/opt/ros/dashing/lib/libgazebo_ros_ray_sensor.so"> <ros> <namespace>/laser</namespace> <argument>~/out:=scan</argument> </ros> <output_type>sensor_msgs/LaserScan</output_type> </plugin> </sensor> </link> </model> </sdf>
when i list out topics i get the topics as
/clock [rosgraph_msgs/msg/Clock]
/laser/parameter_events [rcl_interfaces/msg/ParameterEvent]
/laser/rosout [rcl_interfaces/msg/Log]
/laser/scan [sensor_msgs/msg/LaserScan]
but whenever i echo the topic /laser/scan; it sometimes shows data, and sometimes says that "it can not determine the type for the passed topic"
How do i make sure that the data is always there, what could be going wrong here. Thanks.
here are the relevant terminal output
[INFO] [gzserver-1]: process started with pid [28856]
[INFO] [gzclient --verbose -2]: process started with pid [28858]
[INFO] [gz-3]: process started with pid [28860]
[INFO] [xterm-4]: process started with pid [28862]
[gzclient --verbose -2] Gazebo multi-robot simulator, version 9.0.0
[gzclient --verbose -2] Copyright (C) 2012 Open Source Robotics Foundation.
[gzclient --verbose -2] Released under the Apache 2 License.
[gzclient --verbose -2] http://gazebosim.org
[gzserver-1] Gazebo multi-robot simulator, version 9.0.0
[gzserver-1] Copyright (C) 2012 Open Source Robotics Foundation.
[gzserver-1] Released under the Apache 2 License.
[gzserver-1] http://gazebosim.org
[gzserver-1]
[gzclient --verbose -2] [Msg] Waiting for master.
[gzclient --verbose -2] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
[gzclient --verbose -2] [Msg] Publicized address: 192.168.2.1
[gzclient --verbose -2] [Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/aamir/.gazebo/models/.git"
[gzclient --verbose -2] [Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/aamir/.gazebo/models/gazebo_models"
[gzclient --verbose -2] [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
[gzclient --verbose -2] [Err] [REST.cc:205] Error in REST request
[gzclient --verbose -2] libcurl: (51) SSL: no alternative certificate subject name matches target host name 'api.ignitionfuel.org'
[gzclient --verbose -2] [Err] [ModelDatabase.cc:390] Unable to parse model.config for model[http://gazebosim.org/models/bin_4_dropping_task]
[gz-3] Warning [parser.cc:626] Can not find the XML attribute 'version' in sdf XML tag for model: foggy_lidar_n1. Please specify the SDF protocol supported in the model configuration file. The first sdf tag in the config file will be used
[gzserver-1] [Msg] Waiting for master.
[gzserver-1] [Msg] Connected to gazebo master @ http://127.0.0.1:11345
[gzserver-1] [Msg] Publicized address: 192.168.2.1
[gzserver-1] [Wrn] [gazebo_gps_plugin.cpp:78] [gazebo_gps_plugin]: drone::gps0 using gps topic "gps0"
[gzserver-1] [Wrn] [gazebo_gps_plugin.cpp:203] [gazebo_gps_plugin] Using default update rate of 5hz
[INFO] [gz-3]: process has finished cleanly [pid 28860]
[gzserver-1] [Msg] Connecting to PX4 SITL using TCP
[gzserver-1] [Msg] Lockstep is enabled
[gzserver-1] [Msg] Speed factor set to: 1
[gzserver-1] [Wrn] [gazebo_mavlink_interface.cpp:152] No identifier on joint. Using 0 as default sensor ID
[gzclient --verbose -2] [Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/user_camera/pose, deleting message. This warning is printed only once.
Asked by zebo on 2021-08-11 03:44:30 UTC
