[ignition] Bug or Feature? Service to add resource path to ignition goes to timeout.
I'm using the service /gazebo/resource_paths/add to add a resource path to the simulation. Everything is working, but the service says that it has reached the timeout. I'm not sure if this is supposed to happen, so I wanted to confirm here before openning an issue in ign-transport.
Here is what I did:
Get current resource paths:
$ ign service -r "" --reqtype=ignition.msgs.Empty --reptype=ignition.msgs.StringMsg_V --timeout=1000 --service=/gazebo/resource_paths/get Only one returned:
data: "/home/matosinho/dev/ROS2/brov/brov_dep/src/bir_ign_underwater_worlds"
Add resource path:
$ ign service -r "data: '/home/matosinho/dev/ROS2/brov/brov_main/src/brov_ignition'" --reqtype=ignition.msgs.StringMsg_V --reptype=ignition.msgs.Empty --timeout=1000 --service=/gazebo/resource_paths/add
Goes to Timeout:
Service call timed out
It returns the previous one and the one I added.
data: "/home/matosinho/dev/ROS2/brov/brov_dep/src/bir_ign_underwater_worlds" data: "/home/matosinho/dev/ROS2/brov/brov_main/src/brov_ignition"
As you can see, I successfully added the path, but the service goes to timeout.
This error message comes from ign.cc in ign tranport. From looking at the code, this messege appears to be sent only if the service does not get executed, so... Should I open an issue better detailing the problem in ign-transport? Or am I missing something?
Asked by matosinho on 2021-08-29 07:34:55 UTC
That's just a misleading error message, the service call actually succeeded. See this issue tracking the problem:
https://github.com/ignitionrobotics/ign-transport/issues/97#issuecomment-613966156
Asked by chapulina on 2021-10-07 13:09:43 UTC
