How to capture a point cloud from deph sensor
Hello everyone.
I am trying to simulate a rgbd camera. I can manage to capture pictures from the camera, but not from the depth sensor.
Basically, this is the important part of the sdf file:
<?xml version="1.0"?>
<sdf version="1.6">
  <model name="realsense">
    <link name='cameraLink'>
        <sensor name='depth' type='depth'>
        <topic>realsense</topic>
        <always_on>true</always_on>
        <camera name='d435i_depth'>
          <horizontal_fov>1.01229</horizontal_fov>
            <width>1920</width>
            <height>1080</height>
          <depth_camera>
              <near>0.3</near>
              <far>3.0</far>
          </depth_camera>
      <sensor name='color' type='camera'>
        <update_rate>10</update_rate>
        <camera name='d435i'>
            <width>1920</width>
It publishes information to two gazebo topics, one from the camera and another one from the depth sensor. Both topics are of type gazebo.msgs.ImageStamped. I am subscribed to both topics in the same way:
    int width = static_cast<int>(msg->image().width());
    int height = static_cast<int>(msg->image().height());
    char *data;
    data = new char[msg->image().data().length() + 1];
    memcpy(data, msg->image().data().c_str(), msg->image().data().length());
    cv::Mat image(height, width, CV_8UC3, data);
    cv::resizeWindow("image", height, width);
    cv::imshow("image", image);
    cv::waitKey(10);
    lastPicture_ = image;
    delete data;
However, when I show the pictures, something is wrong with the depth image. Here it is the camera picture:
image description
And here, the depth image:
image description
It has to be a problem of interpretation, because with the Gazebo GUI ("Topic visualization"), it is possible to see the depth image correctly:
image description
Someone knows how to solve it? Many thanks in advance.
Asked by carlosprados11 on 2021-09-02 10:54:58 UTC
If you run it with gazebo --verbose, does something appeared in the log? Could you please provide a full world file ready to reproduce the problem? Thanks.
Asked by Jose Luis Rivero on 2021-09-03 10:06:37 UTC
I am running with verbose, but nothing appears. Actually, the gazebo topic publication looks good because with the "topic visualization" it is possible to observe correctly both pictures. So, I guess the problem is in the interpretation of the information of the depth topic.
Here you may find a world file with the camera: https://drive.google.com/file/d/1lwDqdjeMRHdEpWlSIFv--acdXcLzYQCe/view?usp=sharing
In the SDF file, it would be necessary to set the visual and collision information.
Asked by carlosprados11 on 2021-09-06 03:15:00 UTC
