Ign Tools crashing when running binary.
Hello all, I am trying to build Sdformat from source. It relies on Ign-tools which I have built locally and working as expected. Sdformat builds but fails to pass UNITignTEST because the 'ign' command outputs the following when run:
I cannot find any available 'ign' command:
* Did you install any ignition library?
* Did you set the IGN_CONFIG_PATH environment variable?
E.g.: export IGN_CONFIG_PATH=$HOME/local/share/ignition
When I run ign with this as well:
IGN_CONFIG_PATH=<path to Ign-utils share/ignition folder> ./ign
It gives me the same error. Any idea what I might be doing wrong with running and using ign?
I found that others had the same problem:
- https://github.com/ignitionrobotics/ign-gazebo/issues/25 <- Problem was with Homebrew installs and the solution basically says to wait for a couple of months until they can make every library have its own binary.
Asked by TheCynosure on 2021-09-14 12:47:25 UTC
