gazebo freezes with gazebo_ros_control, libgazebo_ros_control
I have a model file which uses
<gazebo>
<robotNamespace>/rrbot</robotNamespace>
Without these lines, the file loads fine, using this launch file line:
<node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" args="-x 0 -y 0 -z 1 -file $(find
keyboard_control_arm)/urdf/output.urdf -urdf -model beam_balance" respawn="false" output="screen" />
With these lines, gazebo freezes (gzserver and gzclient). I don't have anything else in my launch file except empty world.launch. What could be going wrong?
Asked by acenturyandabit on 2021-09-26 01:02:22 UTC
The answer turned out to be: You NEED to put the model file urdf raw text as a parameter under /robot_description, so that gazebo_ros_control plugin knows what your robot is up to. Something like
<param name="robot_description" textfile="$(find your_pkg)/urdf/your_urdf.urdf" />
Hope that saves someone four hours!
Asked by acenturyandabit on 2021-09-26 01:08:21 UTC
