Gazebo not converting base_link <gazebo ref> data
I'm testing some gazebo physics and I needed to change the friction of simple shapes.
I started applying friction to a caster wheel, for example, by using the tag <gazebo> and it works as expected.
Although, if I try to set the same <mu1> or <mu2> to a base link (the first link of my model), it does not work.
I'm using gazebo 11.5.1 and executing the command
gz sdf -p test.urdf > test.sdf
The input: https://gist.github.com/marcoarruda/0636d17a0c0c52500a991f1f7f02544b
The output: https://gist.github.com/marcoarruda/9df1339d9f4dd916d85473ecd9d13324
Asked by marcoarruda on 2021-09-30 10:04:27 UTC
I found the error!
Let me share it:
It was set name for the collision and visual tags. We must not set these attributes, since SDF conversion will do it automatically.
Asked by marcoarruda on 2021-10-04 15:51:35 UTC
