Camera data rate not consistent
I am using a camera sensor to record frames from a simulation and produce videos. However, I noticed that when generating the video (using the same fps as the updaterate of the sensor), the resulting video will not be of the expected length, but longer. I suspect that the updaterate of the sensor actually works with the real time of the simulation, instead of the fictional one (which is the one to be used). Is that possible? I can solve the issue by generating the video with a different fps, computed employing the number of generated frames and the simulation time; however, this is quite tedious.
Thanks in advance for the help
Asked by andrea_pat on 2021-10-10 17:03:55 UTC
