How to proceed when gazebo faills to load world?
Hi, I'm noob. My goal is to run a plane in gazebo and record the response to simulated step inputs. However, I get stuck right away.
If I run gazebo by itself, that works
$ gazebo --verbose
Gazebo multi-robot simulator, version 9.19.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.1.203
[Msg] Loading world file [/usr/share/gazebo-9/worlds/empty.world]
Running gazebo with a world produces no output
$ gazebo --verbose worlds/iris_arducopter_runway.world
Warning [parser.cc:759] XML Attribute[xmlns:xacro] in element[sdf] not defined in SDF, ignoring.
[Msg] Loading world file [/usr/share/gazebo-9/worlds/iris_arducopter_runway.world]
[libprotobuf FATAL ./google/protobuf/repeated_field.h:1453] CHECK failed: (n) >= (0):
terminate called after throwing an instance of 'google::protobuf::FatalException'
what(): CHECK failed: (n) >= (0):
[Err] [Connection.cc:546] Connection[0] Closed during Read
[Err] [ConnectionManager.cc:135] Unable to read from master
[Err] [gazebo_shared.cc:77] Unable to initialize transport.
[Err] [gazebo_client.cc:56] Unable to setup Gazebo
Check for file irisarducopterrunway.world
$ sudo find / -name iris_ardu*.wo1rld -print
/usr/share/gazebo-9/worlds/iris_arducopter_demo.world
/usr/share/gazebo-9/worlds/iris_arducopter_cmac.world
What should I do?
Asked by JohnUAV on 2021-10-15 10:08:28 UTC
