2
Libogre Error
asked 2012-11-24 22:13:51 -0500
mfahad gravatar image
Hi all,
I am facing a problem with Gazebo. When I install it on my machine running Ubuntu Linux 12.04, it works fine but when I restart the computer and try to run it, it gives me the following error.
gazebo: error while loading shared libraries: libOgreRTShaderSystem.so.1.7.3: cannot open shared object file: No such file or directory
Has any body else faced the same problem? What might be the possible solution?
2
answered 2012-11-27 12:17:53 -0500
nkoenig gravatar image
Make sure you sourced the setup.sh file that is installed in /usr/share/gazebo-<version>.
I place the following line in my ~/.bashrc file so that setup.sh is sourced at the appropriate time:
source /usr/share/gazebo-1.2/setup.sh
Thanks, that fixed it.
mfahad gravatar imagemfahad ( 2012-11-28 09:11:07 -0500 )edit
@mfahad, please mark Nate's answer as being correct if possible so that others can easily see the problem is solved.
asomerville gravatar imageasomerville ( 2012-11-29 13:49:52 -0500 )edit
Asked: 2012-11-24 22:13:51 -0500
Seen: 604 times
Last updated: Nov 27 '12
