Default configuration file Ignition Fuel is not being used
I am trying to download my private models from Fuel, and I am getting:
REST response code: 401
I already updated the default configuration file in the $HOME/.ignition/fuel/config.yaml, adding the private-token, but it is not working. If I add the args:
-p --header 'Private-token: ...'
or
-c $HOME/.ignition/fuel/config.yaml
it works and download the model.
Am I configuring the "default" in the wrong place, or is this a bug?
Asked by Filipe Almeida on 2021-10-28 07:36:34 UTC
