A recent update breaks compilation.
I've recently done a sudo apt-get update && upgrade
on my machine and it seems that the update broke the compilation of my project. In particular, any package dependent on ros gazebo packages no longer finds the ignition-math library. The full error message is:
CMake Error at CMakeLists.txt:48 (addlibrary): Target "XXX" links to target "ignition-math6::requested" but the
target was not found. Perhaps a findpackage() call is missing for an IMPORTED target, or an ALIAS target is missing?
As far as I could tell, the offending update was something related to a recent gazebo and gazebo pkgs update. I run a ubuntu 20.04 focal fossa machine with ros2 foxy and gazebo11; I installed the ros-foxy-gazebo-ros-pkgs via apt. Funnily enough, if I link other packages to ignition-math6 directly, this compiles and links fine. However, all the plugins that use the gazebo_ros as dependency fail with the above error. Has anyone had a similar experience or knows how to set the ignition-math path to compile correctly?
Asked by antbre on 2021-11-01 08:15:47 UTC
