Gazebo build for ros2 foxy stuck at 66%
gazebo_plugins:build 66% -2min 32.6s
gets stuck there , pc crashes basically , timers stop moving
http://gazebosim.org/tutorials?tut=ros2_installing&cat=connect_ros
all steps followed from that , problem happens at colcon build part with no prior errors, cant add a screenshot as it just crashes
Ros2-Foxy
Asked by yagizzha on 2021-11-08 05:12:50 UTC
colcon (build tool) can be aggressive in its number of parallel workers and parallel compilation threads specially if the machine is not very powerful. Let's try to reduce the number of parallel compilation threads:
MAKE_JOBS=1 colcon build --parallel-workers 1
You can increase the 1's in that command to gain some speed but will increase the amount of memory used.
Asked by Jose Luis Rivero on 2021-11-08 17:22:11 UTC
Sadly that didnt work either , https://postimg.cc/gxRVW2sb that link is what it looks like , now stuck at 64% instead of 66
Asked by yagizzha on 2021-11-09 02:17:01 UTC
Could you please attach the output of MAKE_JOBS=1 colcon build --event-handlers console_direct+ --parallel-workers 1?
Asked by Jose Luis Rivero on 2021-11-09 05:22:45 UTC
found another fix and trying to reinstall might cause problems again so i wont be able to test this , thanks for the help tho
deleting everything ros/gz related then redownloading did the trick
Asked by yagizzha on 2021-11-10 02:15:55 UTC
