How do you add collision and physical properties to Actor model?
I am trying to simulate an environment where my bot has to interact with walking actors but the models keep walking through walls and my bot cannot detect them with sensors. How can I add collision to the Actor Model?
Below is my world sdf file being used.
<?xml version="1.0" ?>
<sdf version='1.7'>
<world name='default'>
<model name='ground_plane'>
<static>1</static>
<link name='link'>
<collision name='collision'>
<plane>
<normal>0 0 1</normal>
<size>100 100</size>
</plane>
<surface>
<friction>
<ode>
<mu>100</mu>
<mu2>50</mu2>
</ode>
<torsional>
<ode/>
</torsional>
</friction>
<contact>
<ode/>
</contact>
<bounce/>
</surface>
<visual name='visual'>
<cast_shadows>0</cast_shadows>
<plane>
</plane>
<script>
<name>Gazebo/Grey</name>
</script>
<enable_wind>0</enable_wind>
<kinematic>0</kinematic>
<gravity>0 0 -9.8</gravity>
<magnetic_field>6e-06 2.3e-05 -4.2e-05</magnetic_field>
<atmosphere type='adiabatic'/>
<physics type='ode'>
<max_step_size>0.005</max_step_size>
<real_time_update_rate>1000</real_time_update_rate>
</physics>
<scene>
<ambient>0.4 0.4 0.4 1</ambient>
<background>0.7 0.7 0.7 1</background>
<shadows>1</shadows>
</scene>
<wind/>
<spherical_coordinates>
<surface_model>EARTH_WGS84</surface_model>
<latitude_deg>0</latitude_deg>
<longitude_deg>0</longitude_deg>
<elevation>0</elevation>
<heading_deg>0</heading_deg>
</spherical_coordinates>
<actor name="actor1">
<skin>
<filename>walk.dae</filename>
</skin>
<animation name="walking">
<interpolate_x>true</interpolate_x>
</animation>
<script>
<trajectory id="0" type="walking">
<waypoint>
<time>0</time>
<pose>2 2 0 0 0 -1.57</pose>
</waypoint>
<waypoint>
<time>2</time>
<pose>2 -2 0 0 0 -1.57</pose>
</waypoint>
<waypoint>
<time>2.5</time>
<pose>2 -2 0 0 0 1.57</pose>
</waypoint>
<waypoint>
<time>7</time>
<pose>2 2 0 0 0 1.57</pose>
</waypoint>
<waypoint>
<time>7.5</time>
</waypoint>
</trajectory>
</script>
</actor>
</world>
Asked by Julian94 on 2021-11-10 18:07:02 UTC
If I were you, I would just create a sdf to import that .dae and add collision then import that sdf inside this world sdf. See here: https://github.com/chapulina/dolly/blob/foxy/dolly_gazebo/models/casual_female/model.sdf for example.
That's my preference way.
Anyway back to your question,
I think your actor is not defined as a model. So, you need to define model then add collision in it. Try that
Asked by kakcalu13 on 2022-02-17 10:23:27 UTC
