Ignition Gazebo gripper ignores cube collision
I am using ros foxy with ignition citadel. I am testing ignros2control using panda robot and when I am trying to grip a cube the hand simply goes through it. At the same time this happen there is a huge drop in the real time factor, which I assume is the physics engine detecting a collision and not knowing how to handle it. Is the error due to ros2_control or is it another problem ?
I am using this to spawn panda. The world file is based off this but the same behavior also happen if no world is provided.
<sdf version='1.7'>
<uri>
https://fuel.ignitionrobotics.org/1.0/AndrejOrsula/models/panda
</uri>
<plugin name='ignition_ros2_control::IgnitionROS2ControlPlugin' filename='ignition_ros2_control-system'>
<robot_param>robot_description</robot_param>
<robot_param_node>robot_state_publisher</robot_param_node>
<parameters>/workspaces/Ignition/ubb/ignitiondev/install/share/simple_arm/config/panda_ros_controllers.yaml</parameters>
<!-- Need to find a way to set this programatically -->
I am launching ignition using this launch file
import os
import xacro
from ament_index_python.packages import get_package_share_directory
from launch_ros.actions import Node
from launch import LaunchDescription
from launch.actions import (DeclareLaunchArgument, ExecuteProcess,
IncludeLaunchDescription)
from launch.launch_description_sources import PythonLaunchDescriptionSource
def load_file(package_name, file_path):
package_path = get_package_share_directory(package_name)
absolute_file_path = os.path.join(package_path, file_path)
try:
with open(absolute_file_path, 'r') as file:
return file.read()
except EnvironmentError: # parent of IOError, OSError *and* WindowsError where available
return None
def generate_launch_description():
pkg_name = "simple_arm"
pkg_ros_ign_gazebo = get_package_share_directory('ros_ign_gazebo')
pkg_share = get_package_share_directory(pkg_name)
ignition = IncludeLaunchDescription(
PythonLaunchDescriptionSource(
os.path.join(pkg_ros_ign_gazebo, 'launch', 'ign_gazebo.launch.py'),
spawn = Node(package='ros_ign_gazebo', executable='create',
arguments=[
'-name', 'panda',
'-x', '0',
'-z', '0',
'-Y', '0',
'-file', os.path.join(pkg_share, "urdf", "panda_ign.sdf",)],
output='screen')
robot_description_config = xacro.process_file(
os.path.join(
pkg_share,
"urdf",
"panda.urdf.xacro",
robot_description = {"robot_description": robot_description_config.toxml()}
robot_state_publisher = Node(
package="robot_state_publisher",
executable="robot_state_publisher",
name="robot_state_publisher",
output="both",
parameters=[robot_description],
load_controllers = []
for controller in [
"panda_arm_controller",
"panda_hand_controller",
"joint_state_broadcaster",
load_controllers += [
ExecuteProcess(
cmd=[
"ros2 control load_controller --set-state start {}".format(controller)],
shell=True,
output="screen",
return LaunchDescription([
DeclareLaunchArgument(
'ign_args',
default_value=[os.path.join(
pkg_share, 'worlds', 'empty.sdf'), " -r"],
description='Ignition Gazebo arguments'),
ignition,
spawn,
robot_state_publisher,
] + load_controllers
Moveit and rviz are launched using modified launch file from the move_group tutorial and the controller as well as advertizsing the object to rviz is custom made. I have not included them since i do not think they are relevant since all they do is tell moveit which object to move to.
Asked by 09ubberboy90 on 2021-12-15 11:36:52 UTC
Thanks to AndrejOrsula's answer. Using an effort controller was indeed the solution. However I used this fork from SC-Robotics instead of his own fork as I am using ros foxy
Asked by 09ubberboy90 on 2022-01-12 11:28:30 UTC
What command interface are you using? AFAIK, you need to use
effort
because bothposition
andvelocity
bypass the physics engine. Therefore, neither of these are suitable if you want a controlled model (robot) to interact with other models (objects). Maybe you could get away withvelocity
command interface if your control frequency is slower than the simulation step size, but I am not sure.For effort-controlled JTC, see https://github.com/ros-controls/ros2_controllers/pull/225
Asked by AndrejOrsula on 2021-12-19 07:23:57 UTC
I am indeed using position. I tried using a mixed of both position and velocity, which solved the hand going through the cube but i still could't grip. I tried to use the effort controller but even after I built it, moveit still report that it's not implemented. I only have ros-foxy-ros-control installed from binary. Do i need to also install ros-control from source and/or moveit ?
Asked by 09ubberboy90 on 2022-01-06 12:09:25 UTC
Until the PR is merged, building
ros2_controllers
with https://github.com/ros-controls/ros2_controllers/pull/225 from source should be enough in order to enable JointTrajectoryController with effort-only command interface. Of course, your version ofros2_control
must be compatible with theros2_controllers
that you want to build (as long asros2_controllers
compiles, it should be good).Asked by AndrejOrsula on 2022-01-07 04:07:01 UTC
