Torque sensing of programmatically created joints
Hi everyone!
I am working with a robot that is successfully dynamically generated in gazebo (it is not created from a urdf file). I would like to introduce a joint sensor but because of the way the robot is spawned, I cannot apply the classical method of inserting a sensor in the description file (since there is none), as in the tutorial http://gazebosim.org/tutorials?tut=forcetorquesensor&cat=sensors
Let me give some context. Essentially, the robot is constituted of smaller polygonal units, each of which is spawned programmatically by creating a temporary sdf.
bot.SetFromString(
"<sdf version='1.4'>\
<model name='"+bot_name+"'>\
<pose>"+strpose+"</pose>\
<link name='L_"+bot_name+"'>\
<inertial>\
<inertia>\
<ixx>"+ixx+"</ixx>\
<ixy>"+ixy+"</ixy>\
<ixz>"+ixz+"</ixz>\
<iyy>"+iyy+"</iyy>\
<iyz>"+iyz+"</iyz>\
<izz>"+izz+"</izz>\
</inertia>\
<mass>"+mass+"</mass>\
</inertial>\
<collision name='collision'>\
<geometry>\
<mesh><uri>"+mesh_location+"</uri></mesh>\
</geometry>\
</collision>\
<visual name='visual'>\
<geometry>\
</geometry>\
</visual>\
</link>\
</model>\
</sdf>"
this->world->InsertModelSDF(bot);
// parent_edge and bot_edge are the edges by which the two polygons are connected
CJ->JointCreation(parent_name, bot_name, parent_edge, bot_edge, joint_type, angle);
The joint between a parent and child polygon is programmatically created with JointCreation()
void CreateJoint::JointCreation(std::string parent, std::string child, int parent_edge, int child_edge, std::string type, double angle){
//here are geometrical computations to correctly set the axis of rotation, based on the parent edge, child edge and joint angle
gazebo::physics::JointPtr joint = this->world->Physics()->CreateJoint(type, this->world->ModelByName(parent));
joint->SetName(parent+"_to_"+child);
joint->Attach(this->world->ModelByName(parent)->GetLink("L_"+parent),this->world->ModelByName(child)->GetLink("L_"+child));
joint->Load(this->world->ModelByName(parent)->GetLink("L_"+parent),this->world->ModelByName(child)->GetLink("L_"+child), JointPose);
joint->SetModel(this->world->ModelByName(child));
if(type == "revolute"){
joint->SetAxis(0, joint_axis);
joint->Init();
std::cout<< "Joint created : " << joint->GetName() << std::endl;
this->MStruct->add_joint(joint->GetName(), joint, angle);
if(type=="revolute"){
JC->JointMotorPosition(joint, joint->Position(0) + angle, 0);
And the constructor of the joint
CreateJoint::CreateJoint(gazebo::physics::WorldPtr &world, ros::NodeHandle* rosnode,
sdf::ElementPtr sdf, Bot_Structure *botStruct, Joint_control_srv* JC){
this->rosnode = rosnode;
this->sdf = sdf;
this->world = world;
this->MStruct = botStruct;
this->JC = JC;
this->serviceThread1 = std::thread(std::bind(&CreateJoint::init_Service_Creation, this));
this->serviceThread2 = std::thread(std::bind(&CreateJoint::init_Service_Destruction, this));
CreateJoint::CreateJoint(){}
I searched the forums for similar questions but unfortunately found nothing. I believe I could use the ForceTorqueSensor class in the JointCreation() function, but so far I only got segfaults when creating the joints. Could anyone please point me in the right direction?
Thanks a lot and happy holidays!
Asked by stnc199 on 2021-12-24 04:05:50 UTC
