undefined symbol: _ZN6google8protobuf8internal14WireFormatLite11WriteUInt64EimPNS0_2io17CodedOutputStreamE
I am trying to launch empty world describing in turtlebot3 simulation in Gazebo link. The Gazebo version is Gazebo9. I am using ubuntu 18.04 and melodic. When I am trying to launch the file
roslaunch turtlebot3_gazebo turtlebot3_world.launch
An error is occurring which shows that
gzclient: symbol lookup error: /usr/lib/x8664-linux-gnu/libignition-msgs1.so.1: undefined symbol: _ZN6google8protobuf8internal14WireFormatLite11WriteUInt64EimPNS02io17CodedOutputStreamE
[gazebogui-3] process has died [pid 14418, exit code 127, cmd /opt/ros/melodic/lib/gazeboros/gzclient _name:=gazebogui _log:=/home/marzan/.ros/log/04190f0e-6996-11ec-a084-780cb83aac64/gazebogui-3.log]. log file: /home/marzan/.ros/log/04190f0e-6996-11ec-a084-780cb83aac64/gazebo_gui-3.log*
what should I need to do? I have tried to uninstall every protobuf. But I am having another error when I am trying to remove libprotobuf-lite10. The error is
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: libkf5parts-plugins : Depends: libkf5parts5 (>= 4.96.0) but it is not going to be installed qml-module-org-kde-kquickcontrolsaddons : Depends: libkf5declarative5 (>= 5.44.0-0ubuntu3) but it is not going to be installed Depends: libkf5quickaddons5 (>= 5.3.0+git20141016.0334) but it is not going to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
What should I need to do in this circumstance?
Asked by marzan on 2021-12-30 12:47:30 UTC
