Ignition Edifice Gazebo black screen
Hi There,
I followed the instructions to install ignition with the binary installation. After that I tried to start a simple gazebo world. However I only get a black window.
When I try ign gazebo or ign gazebo shapes.sdf, I only get a black screen.
When I use ign gazebo.sdf -v I get the following
[Msg] Ignition Gazebo Server v5.3.0
[Msg] Ignition Gazebo GUI v5.3.0
[Msg] Loading SDF world file[/usr/share/ignition/ignition-gazebo5/worlds/shapes.sdf].
[Msg] Loaded level [3]
[Msg] No systems loaded from SDF, loading defaults
[Msg] Create service on [/world/shapes/create]
[Msg] Remove service on [/world/shapes/remove]
[Msg] Pose service on [/world/shapes/set_pose]
[Msg] Light configuration service on [/world/shapes/light_config]
[Msg] Physics service on [/world/shapes/set_physics]
[Msg] Enable collision service on [/world/shapes/enable_collision]
[Msg] Disable collision service on [/world/shapes/disable_collision]
[Msg] Material service on [/world/shapes/visual_config]
[Msg] Serving world controls on [/world/shapes/control] and [/world/shapes/playback/control]
[Msg] Serving GUI information on [/world/shapes/gui/info]
[Msg] World [shapes] initialized with [default_physics] physics profile.
[Msg] Serving world SDF generation service on [/world/shapes/generate_world_sdf]
[Msg] Serving world names on [/gazebo/worlds]
[Msg] Resource path add service on [/gazebo/resource_paths/add].
[Msg] Resource path get service on [/gazebo/resource_paths/get].
[Msg] Resource paths published on [/gazebo/resource_paths].
[GUI] [Wrn] [Application.cc:669] [QT] file:///usr/lib/x86_64-linux-gnu/qt5/qml/QtQuick/Dialogs/DefaultFileDialog.qml:102:33: QML Settings: Failed to initialize QSettings instance. Status code is: 1
[GUI] [Wrn] [Application.cc:669] [QT] file:///usr/lib/x86_64-linux-gnu/qt5/qml/QtQuick/Dialogs/DefaultFileDialog.qml:102:33: QML Settings: The following application identifiers have not been set: QVector("organizationName", "organizationDomain")
[GUI] [Wrn] [Application.cc:669] [QT] file::/Gazebo/GazeboDrawer.qml:147:3: QML Dialog: Binding loop detected for property "implicitHeight"
[Msg] Found no publishers on /stats, adding root stats topic
[Msg] Found no publishers on /clock, adding root clock topic
[Msg] Serving scene information on [/world/shapes/scene/info]
[Msg] Serving graph information on [/world/shapes/scene/graph]
[Msg] Serving full state on [/world/shapes/state]
[Msg] Serving full state (async) on [/world/shapes/state_async]
[Msg] Publishing scene information on [/world/shapes/scene/info]
[Msg] Publishing entity deletions on [/world/shapes/scene/deletion]
[Msg] Publishing state changes on [/world/shapes/state]
[Msg] Publishing pose messages on [/world/shapes/pose/info]
[Msg] Publishing dynamic pose messages on [/world/shapes/dynamic_pose/info]
When I tried ign service -l no output was shown. ign service --versions gave me 10.1.0.
I have also tried to use ogre and ogre2
Asked by TImSw on 2022-01-06 03:51:47 UTC
After running with ign gazebo.sdf -v 4 it turned out it was an ignition transport issue, which I then solved by resting my firewall because it was blocking multicast.
Asked by MhAyman on 2022-02-23 10:55:18 UTC
I faced a very similar issue with gazebo citadel on Ubuntu 20.04. Turning off the firewall with sudo ufw disable solved the issue for me but this is only a temporary solution. I suppose by default the ignition gazebo server used my devices LAN IP to listen for incoming client requests, which is why the firewall blocked it. In any case, shifting the address to local loopback i.e. 127.0.0.1 with export IGN_IP=127.0.0.1 is better than disabling the firewall, provided you want to run both server and client on the same machine.
Asked by ArthurGomes on 2023-08-03 23:16:22 UTC
I'm facing the same issue, but I've installed it from source. But I already have a gazebo11 binary installed, do you have a similar situation?
Asked by MhAyman on 2022-02-23 07:06:43 UTC
