Does Gazebo support declaration of variables using DOCTYPE?
I'm working on an SDF file written in XML used to describe a robotic arm. There are many repeated parts in the robot and I'm trying to declare a variable using DOCTYPE and reuse it in different parts of the code. However, I am unable to insert the model into Gazebo (nothing appears).
This is a snippet of my code (I've omitted some unrelated portions of the code):
<?xml version='1.0'?>
<!DOCTYPE sdf [<!ENTITY basesize "1 1 0.1">]>
<sdf version='1.7'>
<model name='working_arm'>
<link name='base'>
<visual name='base_visual'>
<pose>0 0 0.05 0 -0 0</pose>
<size>&basesize;</size>
<link>
<model>
<sdf>
However, the model appears when I remove the DOCTYPE line and replace &basesize; with 1 1 0.1.
Asked by gerald on 2022-01-07 05:23:31 UTC
