Trying to install gazebo11/ros, and am following docs. Where is gazebo_ros_pkgs for ubuntu?
asked 2022-01-13 06:36:26 -0600
LakeWorthB gravatar image
So this page http://gazebosim.org/tutorials?tut=ro... says that I can use various ros-$ROS_DISTRO-gazebo11-ros-pkgs packeges, but I don't actually see that when I use the osrf apt source.
deb http://packages.osrfoundation.org/gaz... focal main
>apt-cache search gazebo11
gazebo11 - Open Source Robotics Simulator
gazebo11-common - Open Source Robotics Simulator - Shared files
gazebo11-dbg - Open Source Robotics Simulator - Debugging Symbols
gazebo11-doc - Open Source Robotics Simulator - Documentation
gazebo11-plugin-base - Open Source Robotics Simulator - base plug-ins
libgazebo11 - Open Source Robotics Simulator - shared library
libgazebo11-dev - Open Source Robotics Simulator - Development Files
answered 2022-01-20 19:41:07 -0600
shonigmann gravatar image
At least from the ROS Distros, the package would be named ros-*VERSION*-gazebo-ros-pkgs (e.g. ros-foxy-gazebo-ros-packages). I don't believe the gazebo version number (11) is included, as different gazebo versions are fairly "tied" to different ros distros (at least with the binaries).
Asked: 2022-01-13 06:36:26 -0600
Seen: 8 times
Last updated: Jan 20
