Hokuyo laser flickering
Hi guys, I'm trying to use multiple hokuyo lasers on one robot. One of them works fine, the others keep flickering and giving wrong readings...
I have attached a picture of my plugin as i don't know how to quoteC:\fakepath\Problem.png
Asked by PumpkinIcedTea on 2022-01-21 00:49:21 UTC
Your min angle and max angle seems weird. It should usually be symmetrical except for a few special cases (which I dont know if the plugin supports).
If that is not the problem: Did you check your world update rate? I had a problem recently that laser scanner flickers randomly when the world update rates (real time update rate and step size of the whole world) are non-standard (real time update rate = 1000 and step size = 0.001). I havent found a solution yet. But in case you dont need the update rates to be different you can try this solution.
Asked by joshuacv on 2022-04-01 00:34:02 UTC
