Using roslaunch to start Gazebo, I got core dump error.
Using roslaunch to start Gazebo, I got below error and no showing model..
gzclient: /build/ogre-1.9-B6QkmW/ogre-1.9-1.9.0+dfsg1/OgreMain/include/OgreAxisAlignedBox.h:252: void Ogre::AxisAlignedBox::setExtents(const Ogre::Vector3&, const Ogre::Vector3&): Assertion `(min.x <= max.x && min.y <= max.y && min.z <= max.z) && "The minimum corner of the box must be less than or equal to maximum corner"' failed.Aborted (core dumped)
How to solve it? and what is the problem? If anyone knows how to solve the problem, please reply...
My xacro file.
<?xml version="1.0" encoding="utf-8" ?>
<robot name="robot">
<material name="grey">
        <color rgba="0.2 0.2 0.2 1.0" />
<!--======================= Links =========================-->
<!-- Body Base -->
<link name="Body_Base">
    <visual>
        <origin rpy="0 0 -1" xyz="0 0 0" />
            <mesh filename="package://rb_description/meshes/visual/_1_base.dae" />
        <material name="grey" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_1_base.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
        <inertia ixx="0.1" iyy="0.1" izz="0.1" ixy="0.0" ixz="0.0" iyz="0.0" />
<!-- Body Module 1 -->
<link name="Body_Module_1">
    <visual>
            <mesh filename="package://rb_description/meshes/visual/_2_module_1.dae" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_2_module_1.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
<!-- Body Module 2 -->
<link name="Body_Module_2">
    <visual>
        <origin rpy="0 0 -1" xyz="0 0 -0.1" />
            <mesh filename="package://rb_description/meshes/visual/_3_module_2.dae" />
    <visual>
            <mesh filename="package://rb_description/meshes/visual/_4_pipe_1.dae" />
    <visual>
            <mesh filename="package://rb_description/meshes/visual/_5_module_3.dae" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_3_module_2.stl" scale="0.001 0.001 0.001" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_4_pipe_1.stl" scale="0.001 0.001 0.001" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_5_module_3.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
<!-- Body Module 3 -->
<link name="Body_Module_3">
    <visual>
        <origin rpy="0 0 -1" xyz="0 0 -0.5" />
            <mesh filename="package://rb_description/meshes/visual/_6_module_dummy.dae" />
    <visual>
            <mesh filename="package://rb_description/meshes/visual/_7_pipe_2.dae" />
    <visual>
            <mesh filename="package://rb_description/meshes/visual/_8_module_4.dae" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_6_module_dummy.stl" scale="0.001 0.001 0.001" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_7_pipe_2.stl" scale="0.001 0.001 0.001" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_8_module_4.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
<!-- Body Module 4 -->
<link name="Body_Module_4">
    <visual>
        <origin rpy="0 0 -1" xyz="0 0 -0.9" />
            <mesh filename="package://rb_description/meshes/visual/_9_module_5.dae" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_9_module_5.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
<!-- Body Module 5 -->
<link name="Body_Module_5">
    <visual>
        <origin rpy="0 0 -1" xyz="0 0.1 -0.9" />
            <mesh filename="package://rb_description/meshes/visual/_10_module_6.dae" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_10_module_6.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
<!-- Body Tool Flange -->
<link name="Body_Tool_Flange">
    <visual>
        <origin rpy="0 0 -1" xyz="0 0.1 -1" />
            <mesh filename="package://rb_description/meshes/visual/_11_tool_flange.dae" />
    <collision>
            <mesh filename="package://rb_description/meshes/collision/_11_tool_flange.stl" scale="0.001 0.001 0.001" />
        <mass value="1" />
<link name="Tool_Center_Point">
    <visual>
        <origin rpy="0 0 0" xyz="0.1 0 -1" />
            <box size="0.001 0.001 0.001" />
<!--======================= Joints =========================-->
<link name="world" />
<joint name="world_fixed" type="fixed">
    <parent link="world" />
    <child link="Body_Base" />
    <origin rpy="0 0 0" xyz="0 0 0" />
<joint name="base" type="revolute">
    <parent link="Body_Base" />
    <child link="Body_Module_1" />
    <axis xyz="0 0 1" />
    <limit effort="10.0" lower="-6" upper="6" velocity="2.5" />
<joint name="shoulder" type="revolute">
    <parent link="Body_Module_1" />
    <child link="Body_Module_2" />
    <origin rpy="0 0 0" xyz="0 0 0.1" />
    <axis xyz="0 1 0" />
<joint name="elbow" type="revolute">
    <parent link="Body_Module_2" />
    <child link="Body_Module_3" />
    <origin rpy="0 0 0" xyz="0 0 0.4" />
    <limit effort="10.0" lower="-2" upper="2" velocity="2.5" />
<joint name="wrist1" type="revolute">
    <parent link="Body_Module_3" />
    <child link="Body_Module_4" />
    <origin rpy="0 0 0" xyz="0 0 0.392" />
<joint name="wrist2" type="revolute">
    <parent link="Body_Module_4" />
    <child link="Body_Module_5" />
    <origin rpy="0 0 0" xyz="0 -0.1 0" />
<joint name="wrist3" type="revolute">
    <parent link="Body_Module_5" />
    <child link="Body_Tool_Flange" />
<joint name="Tool_Flange" type="fixed">
    <parent link="Body_Tool_Flange" />
    <child link="Tool_Center_Point" />
    <origin rpy="0 0 0" xyz="0 -0.09 0" />
    <axis xyz="0 0 0" />
image description
Asked by kim on 2022-02-12 03:14:22 UTC
my first suggestion is run gazebo with the debug and verbose argument in you launch file. run bt on the gdb in launch files cli. disable all plugins if any are used.
installing gazebo from `sudo apt-get ros-melodic' uses a 9.0.0 version. for me, many of these errors disappeared after installing from gazebo. version 9.19.0 as of July 2022.
Asked by dwd394 on 2022-07-07 11:17:50 UTC
