ignition-gazebo sensors problem
I am trying out ignition-gazebo and tried migrating my own robot. i can see the robot in gazebo but when i type ign topic -l, nothing displays on my terminal. I am trying to add IMU to my imu link that i wrote myself. Strangely, when converting from urdf to sdf, the fixed links are all combined into base_link as visuals only..?
This is the sdf for my robot:
<?xml version="1.0" ?>
<sdf version='1.9'>
<world name="mobile_base_arm_world">
  <physics name="1ms" type="ignored">
      <max_step_size>0.001</max_step_size>
      <real_time_factor>1.0</real_time_factor>
  </physics>
      filename="libignition-gazebo-physics-system.so"
      name="ignition::gazebo::systems::Physics">
      filename="libignition-gazebo-user-commands-system.so"
      name="ignition::gazebo::systems::UserCommands">
      filename="libignition-gazebo-scene-broadcaster-system.so"
      name="ignition::gazebo::systems::SceneBroadcaster">
  <plugin filename="ignition-gazebo-sensors-system"
          name="ignition::gazebo::systems::Sensors">
          <render_engine>ogre2</render_engine>
  <plugin filename="ignition-gazebo-imu-system"
                name="ignition::gazebo::systems::Imu">
  <gui fullscreen="0">
      <!-- 3D scene -->
    <plugin filename="GzScene3D" name="3D View">
      <ignition-gui>
      <title>3D View</title>
      <property type="bool" key="showTitleBar">false</property>
      <property type="string" key="state">docked</property>
      </ignition-gui>
      <engine>ogre2</engine>
      <scene>scene</scene>
      <ambient_light>0.4 0.4 0.4</ambient_light>
      <background_color>0.8 0.8 0.8</background_color>
    <!-- World control -->
    <plugin filename="WorldControl" name="World control">
      <ignition-gui>
      <title>World control</title>
      <property type="bool" key="resizable">false</property>
      <property type="double" key="height">72</property>
      <property type="double" key="width">121</property>
      <property type="double" key="z">1</property>
      <property type="string" key="state">floating</property>
      <anchors target="3D View">
          <line own="left" target="left"/>
          <line own="bottom" target="bottom"/>
      </anchors>
      </ignition-gui>
      <play_pause>true</play_pause>
      <step>true</step>
      <start_paused>true</start_paused>
      <service>/world/mobile_base_arm_world/control</service>
      <stats_topic>/world/mobile_base_arm_world/stats</stats_topic>
    <!-- World statistics -->
    <plugin filename="WorldStats" name="World stats">
      <ignition-gui>
      <title>World stats</title>
      <property type="double" key="height">110</property>
      <property type="double" key="width">290</property>
          <line own="right" target="right"/>
      </anchors>
      </ignition-gui>
      <sim_time>true</sim_time>
      <real_time>true</real_time>
      <real_time_factor>true</real_time_factor>
      <iterations>true</iterations>
      <topic>/world/mobile_base_arm_world/stats</topic>
    <!-- Entity tree -->
    <plugin filename="EntityTree" name="Entity tree">
    <!-- KeyPublisher plugin-->
    <plugin filename="KeyPublisher" name="Key Publisher"/>
  </gui>
  <light type="directional" name="sun">
    <cast_shadows>true</cast_shadows>
    <pose>0 0 10 0 0 0</pose>
    <diffuse>0.8 0.8 0.8 1</diffuse>
    <specular>0.2 0.2 0.2 1</specular>
    <attenuation>
      <range>1000</range>
      <constant>0.9</constant>
      <linear>0.01</linear>
      <quadratic>0.001</quadratic>
    </attenuation>
    <direction>-0.5 0.1 -0.9</direction>
  </light>
  <model name="ground_plane">
        <plane>
        <normal>0 0 1</normal>
        </plane>
        <plane>
        <size>100 100</size>
        </plane>
        <ambient>0.8 0.8 0.8 1</ambient>
        <specular>0.8 0.8 0.8 1</specular>
  <model name='mobile_base_arm'>
    <link name='base_link'>
        <pose>0.003300089599108126 -0.007011142805224647 0.05420472189833921 0 0 0</pose>
        <mass>0.509189922631763</mass>
          <ixx>0.001703159163787929</ixx>
          <ixy>0.0003808192202099451</ixy>
          <ixz>-9.421534187442308e-05</ixz>
          <iyy>0.002086036036924227</iyy>
          <iyz>5.959024066529462e-05</iyz>
          <izz>0.003677410794031453</izz>
      <collision name='base_link_collision'>
        <pose>0 0 0 0 0 0</pose>
          <mesh>
            <scale>1 1 1</scale>
            <uri>meshes/base_link.STL</uri>
          </mesh>
      <!-- <collision name='base_link_fixed_joint_lump__MPU9250_fl_collision_1'>
        <pose>0.08268 0.08247500000000001 0.11257 0 0 -1.5707963267948966</pose>
          <mesh>
            <uri>meshes/MPU9250_fl.STL</uri>
          </mesh>
      </collision> -->
      <collision name='base_link_fixed_joint_lump__jetson_nano_collision_2'>
        <pose>-0.061339 0.039423 0.02155 0 0 0</pose>
          <mesh>
            <uri>meshes/jetson_nano.STL</uri>
          </mesh>
      <collision name='base_link_fixed_joint_lump__lidar_link_collision_3'>
        <pose>0.04568 -0.059204 0.0658 0 0 0</pose>
          <mesh>
            <uri>meshes/lidar_link.STL</uri>
          </mesh>
      <visual name='base_link_visual'>
          <mesh>
          </mesh>
          <diffuse>1 0.625 0 1</diffuse>
          <ambient>1 0.625 0 1</ambient>
      <!-- <visual name='base_link_fixed_joint_lump__MPU9250_fl_visual_1'>
        <pose>0.08268 0.08247500000000001 0.11257 0 0 -1.5708</pose>
          <mesh>
          </mesh>
          <diffuse>0.1462499983608723 0.7062499970197678 1 1</diffuse>
          <ambient>0.1462499983608723 0.7062499970197678 1 1</ambient>
      </visual> -->
      <visual name='base_link_fixed_joint_lump__jetson_nano_visual_2'>
          <mesh>
          </mesh>
          <diffuse>0 0 0 1</diffuse>
          <ambient>0 0 0 1</ambient>
      <visual name='base_link_fixed_joint_lump__lidar_link_visual_3'>
          <mesh>
          </mesh>
          <diffuse>0 0 1 1</diffuse>
          <ambient>0 0 1 1</ambient>
    <joint name='MPU9250_fl_joint' type='fixed'>
      <pose relative_to='base_link'>0.08268 0.082475 0.11257 0 0 -1.5707963267948966</pose>
      <parent>base_link</parent>
      <child>MPU9250_fl_link</child>
    <link name='MPU9250_fl_link'>
      <pose relative_to='MPU9250_fl_joint'>0 0 0 0 0 0</pose>
        <mass>0.00062885</mass>
          <ixx>2.8418E-08</ixx>
          <ixy>-4.5775E-14</ixy>
          <ixz>-3.7528E-14</ixz>
          <iyy>1.0661E-08</iyy>
          <iyz>4.2588E-14</iyz>
          <izz>3.7595E-08</izz>
      <collision name='MPU9520_fl_collision'>
          <mesh>
          </mesh>
      <visual name='MPU9250_fl_visual'>
          <mesh>
          </mesh>
      <sensor name="imu_sensor" type="imu">
        <update_rate>1</update_rate>
        <topic>imu</topic>
.......other parts of my robot model........
</world>
Asked by MrOCW on 2022-02-13 05:29:09 UTC
