Services calls [/shadow_caster_material_name] and [/shadow_caster_render_back_faces] timed out, cannot use Gazebo
asked 2022-02-16 03:08:19 -0500
ljaniec gravatar image
Setup: Ubuntu 20.04, ROS 2 Galactic, Gazebo (11.10.1-1~focal)
With the update to the gazebo11 (ver 11.10.1) in the last ROS 2 Galactic sync my launch files and Gazebo overall stopped working correctly (services are timed out).
After starting gazebo --verbose I got:
~$ gazebo --verbose
Gazebo multi-robot simulator, version 11.10.1
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.10.103
[Msg] Loading world file [/usr/share/gazebo-11/worlds/empty.world]
[Err] [Scene.cc:227] Service call[/shadow_caster_material_name] timed out
[Err] [Scene.cc:249] Service call[/shadow_caster_render_back_faces] timed out
[Wrn] [Scene.cc:462] Ignition transport [/scene_info] service call failed, falling back to gazebo transport [scene_info] request.
Reverting to the old version of Gazebo packages didn't help, but I am not sure if I did it correctly too (maybe I have missed some dependent ROS packages). I have used:
sudo apt-get install gazebo11=11.9.0-1~focal gazebo11-common=11.9.0-1~focal gazebo11-plugin-base=11.9.0-1~focal libgazebo11=11.9.0-1~focal libgazebo11-dev=11.9.0-1~focal
Gazebo and launcher still won't work even after that. I tried to reinstall everything, Gazebo, ROS2, my GPU drivers (latest recommended nvidia-driver-510).
It starts with empty.world scene, but any launcher (mine or from Nav2 repository and nav2_bringup package, branch" galactic, commit: 4bfedb8) cannot call any services.
When starting gzserver --verbose I am getting standard output, gzclient --verbose gives me every time the same timed-out error.
What is exactly happening? Does anybody have encountered this problem before? How can I solve it? Everything was working before...
I put this issue there already + I haven't found anything more than some issues of the problems with Ogre3d about this kind of services timing out...
There is my ogre.logtoo: https://controlc.com/9061c918
answered 2022-03-20 20:27:53 -0500
There was an update to the Gazebo 11 and luckily I found out what a solution - I had to reset the Firewall settings in Ubuntu 20.04 because even ros2 topic list started to not working correctly.
Then I tried to run gazebo --verbose and it didn't hanged, I could add TB3 to the empty world and see it's topics etc. I think the firewall was disabling the ign-services in the background and they timed-out every time..? Or something similar.
Asked: 2022-02-16 03:08:19 -0500
Seen: 412 times
Last updated: Mar 20 '22
