imported models couldn't collide each other
asked 2022-02-18 03:32:43 -0500
fonawork gravatar image
updated 2022-02-18 21:01:25 -0500
azeey gravatar image
Could you help me how can I make collide imported models?
I downloaded SUV model from here. https://app.ignitionrobotics.org/Open...
and I uploaded this model to my world.sdf as below code. you may find if you click the 'play button', two SUVs will be collided by gravity.
I could find these testing results.
  1. Ignition gazebo's Box, Capsule and Sphere,, etc. can collide each other.
  2. downloaded SUV model with Ignition gazebo's Box, Capsule and Sphere,, etc can collide each other.
  3. downloaded SUV models couldn't collide each other.
<model name='suv_110'>
    <static>0</static>
    <link name='chassis'>
      <collision name='collision'>
        <pose>0 0 0 0 0 -1.57079632679</pose>
          <mesh>
            <scale>0.06 0.06 0.06</scale>
            <uri>https://fuel.ignitionrobotics.org/1.0/openrobotics/models/suv/2/files/meshes/suv.obj</uri>
          </mesh>
      <visual name='visual'>
          <mesh>
          </mesh>
      <pose>0 0 0 0 -0 0</pose>
        <mass>1</mass>
          <ixx>1</ixx>
          <iyy>1</iyy>
          <izz>1</izz>
      <enable_wind>0</enable_wind>
    <pose>20 0 1 0 0 0</pose>
    <self_collide>0</self_collide>   </model>
<model name='suv_111'>
    <static>0</static>
          <mesh>
          </mesh>
          <mesh>
          </mesh>
        <mass>1</mass>
          <ixx>1</ixx>
          <iyy>1</iyy>
          <izz>1</izz>
    <pose>20 0 10 0 0 0</pose>
[Testing environment] - Linux Mint 20.2 - Installed Ignition version is Garden
fonawork gravatar imagefonawork ( 2022-02-20 18:22:30 -0500 )edit
answered 2022-02-20 18:55:58 -0500
updated 2022-02-20 22:14:21 -0500
Have a nice day! azeey.
Unfortunately, it's weird in my testing. I wrote the sdf file based on this example code /usr/share/ignition/ignition-gazebo6/worlds/heightmap.sdf which has ground plane as below code. this example code has already ground plane and if I just add SUVs, it shows that it is getting worse result. SUVs are through the ground plane without any collision. To avoid this, I had to use ground area 'https://fuel.ignitionrobotics.org/1.0/OpenRobotics/models/Ground Plane'.
[solved] That's a plugin reason. by changing loading part of physics plugin from 'heightmap.sdf' to 'tunnel.sdf', it works fine.
<physics name="1ms" type="ignored">
  <max_step_size>0.001</max_step_size>
  <real_time_factor>1.0</real_time_factor>
</physics>
[my testing code]
<sdf version="1.6"> <world name="heightmap"> <physics name="1ms" type="ignored"> <dart> <collision_detector>bullet</collision_detector> </dart> </physics>
<light type="directional" name="sun">
  <cast_shadows>true</cast_shadows>
  <pose>0 0 10 0 0 0</pose>
  <diffuse>0.8 0.8 0.8 1</diffuse>
  <specular>0.2 0.2 0.2 1</specular>
  <attenuation>
    <range>1000</range>
    <constant>0.9</constant>
    <linear>0.01</linear>
    <quadratic>0.001</quadratic>
  </attenuation>
  <direction>-0.5 0.1 -0.9</direction>
</light>
<model name="sphere_red">
  <pose>30 30 10 0 0 0</pose>
  <link name="sphere_link">
        <ixx>3</ixx>
        <iyy>3</iyy>
        <izz>3</izz>
      <mass>3.0</mass>
    <collision name="sphere_collision">
        <sphere>
          <radius>0.5</radius>
        </sphere>
    <visual name="sphere_visual">
        <sphere>
        </sphere>
        <ambient>1 0 0 1</ambient>
        <diffuse>1 0 0 1</diffuse>
        <specular>1 0 0 1</specular>
<model name="sphere_green">
  <pose>30 -30 10 0 0 0</pose>
        <ixx>3</ixx>
        <iyy>3</iyy>
        <izz>3</izz>
      <mass>3.0</mass>
        <sphere>
        </sphere>
        <sphere>
        </sphere>
        <ambient>0 1 0 1</ambient>
        <diffuse>0 1 0 1</diffuse>
        <specular>0 1 0 1</specular>
<model name="sphere_blue">
  <pose>-30 30 10 0 0 0</pose>
        <ixx>3</ixx>
        <iyy>3</iyy>
        <izz>3</izz>
      <mass>3.0</mass>
        <sphere>
        </sphere>
        <sphere>
        </sphere>
        <ambient>0 0 1 1</ambient>
        <diffuse>0 0 1 1</diffuse>
        <specular>0 0 1 1</specular>
<model name="sphere_yellow">
  <pose>-30 -30 20 0 0 0</pose>
        <ixx>3</ixx>
        <iyy>3</iyy>
        <izz>3</izz>
      <mass>3.0</mass>
    </inertial ...
(more)
answered 2022-02-18 21:08:38 -0500
They collide for me. You might be missing the ground plane. You can insert it into your world from Fuel:
  <uri>
  </uri>
image description
Thank you for help, but unfortunately I could see the same result(couldn't collide third one in my question). I modified the code based on the heightmap.sdf file. I uploaded my sdf file.
fonawork gravatar imagefonawork ( 2022-02-20 18:26:41 -0500 )edit
May I ask what's your Ignition Gazebo's version?
fonawork gravatar imagefonawork ( 2022-02-20 20:40:10 -0500 )edit
Could you help me to understand how to use plugins well? Where can I find list of plugins and example code?
fonawork gravatar imagefonawork ( 2022-02-20 22:38:36 -0500 )edit
This tutorial might be useful: https://ignitionrobotics.org/api/gaze.... I tested it on v6.5 and v5.3 and both worked.
Can you try removing <physics name="1ms" type="ignored"> <dart> <collision_detector>bullet</collision_detector> </dart> </physics> from your file?
azeey gravatar imageazeey ( 2022-02-22 13:21:10 -0500 )edit
azeey gravatar imageazeey ( 2022-02-22 13:21:27 -0500 )edit
After changing physics as you mentioned, it works well. Thank you!
fonawork gravatar imagefonawork ( 2022-02-24 19:19:21 -0500 )edit
Asked: 2022-02-18 03:32:43 -0500
Seen: 51 times
Last updated: Feb 20 '22
