Custom sensors and materials simulation in Gazebo: how to simulate specific sensors behaviors for heterogenous materials / buildings.
We are currently working on a simulation for a drone that would evolve in an urban environment. It would flight in front of facades and thus must avoid collision into walls, balconies, windows, etc. To fulfil this task, we added several sensors (lidars, sonars and cameras) to the drone that will jointly understand the surrounding environment by fusing the sensors information. One interesting case would be to have windows that are invisible to lidars and stereo cameras but visible by sonar. Even if the use case seems simple, we couldn’t find any resources or information to simulate different materials (especially their opacity or their transparency) or model sensors behaviors according to the object they face (apart from the transparency it would be interesting to specify different error noise according to the surface seen by a sensor).
Do you think Gazebo is the correct simulation environment to test this kind of behavior? If yes:
Thank you!
Asked by Anil Narassiguin on 2022-02-28 13:20:17 UTC
Cameras see the <visual> part of your models, taking the transparency into account.
GPU lidars also see by <visual>s, but the transparent meshes are also senses by the sensors. CPU lidars, on the other hands, detect by <collision>s. I think sonars also use <collision>s but I'm not sure.
A simple way (but possibly not good in terms of performance, is using different meshes for collisions and visuals, i.e. something may be visible in the camera but not collidable to the robots, and something may not be visible but will block the way of the robots. This may help you in some areas, but may not be all.
More than this, maybe you need to modify the sensors, or add your own.
Asked by Veerachart on 2022-05-16 00:36:05 UTC
