Stacked object gives incorrect accerlerometer reading
I have attached an accelerometer (use the gazebo plugin) to a cylinder, when the cylinder is on the ground plane, the accelerometer works fine. But when I stack the cylinder on top of another cylinder, the accelerometer gives very large and noisy readings.
The following is the physics paratmers:
<physics name='default_physics' default='0' type='ode'>
<gravity>0 0 -9.8066</gravity>
<ode>
<solver>
<type>quick</type>
<iters>10</iters>
<sor>1.3</sor>
<use_dynamic_moi_rescaling>0</use_dynamic_moi_rescaling>
</solver>
<constraints>
<cfm>0</cfm>
<erp>0.2</erp>
<contact_max_correcting_vel>100</contact_max_correcting_vel>
<contact_surface_layer>0.001</contact_surface_layer>
</constraints>
</ode>
<max_step_size>0.002</max_step_size>
<real_time_update_rate>500</real_time_update_rate>
<magnetic_field>6.0e-6 2.3e-5 -4.2e-5</magnetic_field>
</physics>
and the cylinder parameters:
<model name='unit_cylinder'>
<pose frame=''>-4.35932 0.783543 0.5 0 -0 0</pose>
<link name='link'>
<mass>1</mass>
<ixx>0.145833</ixx>
<iyy>0.145833</iyy>
<izz>0.125</izz>
<collision name='collision'>
<cylinder>
<radius>0.5</radius>
<length>1</length>
</cylinder>
<surface>
<contact>
<ode/>
</contact>
<bounce/>
<friction>
<torsional>
<ode/>
</torsional>
<ode/>
</friction>
</surface>
<visual name='visual'>
<cylinder>
<length>1</length>
</cylinder>
<script>
<name>Gazebo/Grey</name>
</script>
<enable_wind>0</enable_wind>
<kinematic>0</kinematic>
Is there any way to adjust the underlying physics to deal with the problem?
Asked by ny on 2022-03-01 09:01:09 UTC
