(Ignition) Run the track example
I'm searching Ignition Gazebo's models which have tracked wheels like a tank, etc. and I could find some example sdf files with classes to enable its track, but it doesn't work in my test.
[example1]
conveyor.sdf
cmd : ign topic -t "/model/conveyor/link/baselink/trackcmd_vel" -m ignition.msgs.Double -p "data: 10.0"
C:\fakepath\conveyor.sdf
[example2]
trackedvehiclesimple.sdf
cmd : ign topic -t "/model/simpletracked/cmdvel" -m ignition.msgs.Twist -p "linear: {x: 1.0}, angular: {z: 0.0}"
C:\fakepath\trackedvehiclesimple.sdf
[other cloud model]
https://app.ignitionrobotics.org/OpenRobotics/fuel/models/coro_hd2_sensor_config_2
Asked by fonawork on 2022-03-02 23:40:43 UTC
Hey! This looks fun project!!
So, I have few questions before I start to work with you on this one. I can't seem to be able to read the sdf ( conveyor.sdf and tracked_vehicle_simple.sdf )
Do you mind to give us link to those sdf files?
Asked by kakcalu13 on 2022-03-03 08:16:21 UTC
It seems hard to find in github, so I will upload sdf files to my question. If you can not download these sdf files, please let me know, I will upload it to question content itself.
Asked by fonawork on 2022-03-03 20:43:48 UTC
For some reason, gazebo answers does not notify me.
I see files now! I will try those files tonight after work.
Asked by kakcalu13 on 2022-03-04 12:22:46 UTC
I'm still checking my methods, but not yet mistakes.
Asked by fonawork on 2022-03-08 04:46:15 UTC
Hey there! Sorry for the delay!
So, I got confused with your sdf file. You posted the command which is for diff_driver plugin. I checked and there is no diff_sensor, just parts like this:
Asked by kakcalu13 on 2022-03-08 08:40:18 UTC
Char limit reached anyway
that's for keyboard to control the model. What you want is
but you wanted track
Asked by kakcalu13 on 2022-03-08 08:43:05 UTC
Ah, garden! I have not try that one out, just fortress or citadel. Sorry! Ill check it out later this week
Asked by kakcalu13 on 2022-03-08 08:50:07 UTC
Thank you! I was able to control above three models just adding plugin named 'diff-drive' with command, but my intention is moving wheels with track like a tank.
Asked by fonawork on 2022-03-09 19:42:42 UTC
It seems that track model has to use TrackedVehicle or TrackController.
Asked by fonawork on 2022-03-09 19:44:24 UTC
Question, did you create those sdf out of air or were you following some example on site?
Asked by kakcalu13 on 2022-03-10 16:03:48 UTC
I just used those sdf files from example1 and example2. You can find those example files if you install ignition. https://ignitionrobotics.org/docs/garden
Asked by fonawork on 2022-03-10 20:52:36 UTC
/home/user/workspace/src/ign-gazebo/examples/worlds
Asked by fonawork on 2022-03-10 21:08:55 UTC
