How to fix gazebo_ros building error?
Hello, I've been trying to setup the Turtlebot3 simulation using the e-manual for several days now, but I'm still running into the same problem over and over again. I am using Ubuntu 20.04 and ROS2 Foxy. Following the instruction of the manual made me install Gazebo for ROS using the debian package:
sudo apt-get install ros-foxy-gazebo-*
After i follow the manual for the installation of the simulation I run into the following error when building the workspace:
CMake Error at CMakeLists.txt:19 (findpackage): By not providing "Findgazeborospkgs.cmake" in CMAKEMODULEPATH this project has asked CMake to find a package configuration file provided by
"gazebo
ros_pkgs", but CMake did not find one.
Could not find a package configuration file provided by "gazeborospkgs" with any of the following names:
gazebo_ros_pkgsConfig.cmake
gazebo_ros_pkgs-config.cmake
Add the installation prefix of "gazeborospkgs" to CMAKEPREFIXPATH or set "gazeborospkgsDIR" to a directory containing one of the above files. If "gazeboros_pkgs" provides a separate development package or SDK, be sure it has been installed.
--- Failed <<< turtlebot3_gazebo [ Exited with code 1 ]
Summary: 12 packages finished [9.23s] 1 package failed: turtlebot3gazebo
1 package had stderr output: turtlebot3
gazebo 1 package not processed
Browsing through the forums for answers I found out that installing the gazebo_ros packages would help. so i did that following these instructions which make me run into the following problem while building:
CMake Error in CMakeLists.txt: Imported target "dart" includes non-existent path
"/include"
in its INTERFACEINCLUDEDIRECTORIES. Possible reasons include:
  • The path was deleted, renamed, or moved to another location.
  • An install or uninstall procedure did not complete successfully.
  • The installation package was faulty and references files it does not provide.
CMake Generate step failed. Build files cannot be regenerated correctly.
Failed <<< gazebo_ros [30.4s, exited with code 1]
Summary: 9 packages finished [41.5s] 1 package failed: gazeboros 1 package had stderr output: gazeboros 2 packages not processed
Does anyone know how to fix this? Sicerly Niklas
Asked by niklas on 2022-03-07 03:24:33 UTC
