Why cafe.world example doesn't show objects if include point light?
I am learning how to use world files and try to use the example cafe.world. The problem is that when I load it in Gazebo it doesn't show any model. After many tries I have discovered that the problem is caused by the point light included in the code of cafe.world. The code is the following:
<light name="point_light" type="point">
<pose>0 -0.377195 6.59868 0 -0 0</pose>
<diffuse>0.784314 0.784314 0.784314 1</diffuse>
<specular>0.0980392 0.0980392 0.0980392 1</specular>
<attenuation>
<range>50</range>
<constant>0.8</constant>
<linear>0</linear>
<quadratic>0.001</quadratic>
</attenuation>
<cast_shadows>0</cast_shadows>
<direction>0 0 -1</direction>
</light>
If I remove the definition of this point light in the code then the world load correctly and models are showed. Please can someone tell why this happens?
Thanks and best regards.
Asked by jec on 2022-03-09 13:18:49 UTC
