After installing the latest Ignition garden, segmentation fault has occurred
I have installed Ignition garden two months ago and it runs well.
After changing my PC, I just installed the latest Ignition garden, but I could see 'segmentation fault' when I type as ign gazebo -v 4
If I have to make it run, how to restore each src ign files to previous version? by using this command?
or how to fix it from source? It's panic for me can not make same developing environments.
ex) ign-rendering$ git reset --hard 1258280eae5834f5687ad5be78e073e73efb47a2
image description
Asked by fonawork on 2022-03-24 00:07:40 UTC
This issue is known and still working on it. See two issues: one and two
You should add your full computer information such as OS, version and all that over there. I am seriously thinking to check and look for the root issue later this weekend. I'm THINKING to do it. I will see.
To anyone who have the same issue as this, post your information on those issue too to help them troubleshoot the issue better.
Asked by kakcalu13 on 2022-03-25 10:16:26 UTC
Thank you for your answer. OS is Linux Mint 20.2. I was able to install and use it by typing 'focal' instead of using 'lsb_release'.
Asked by fonawork on 2022-03-28 01:16:04 UTC
This fixed the issue? Hmm, that's interesting!
I can see why because Focal and Mint have similar architecture.
I'm not sure how to explain, but it sounded makes sense. You should answer your own question and mark it as solved so that way, others can see the similar issue!
Asked by kakcalu13 on 2022-03-28 08:58:13 UTC
I'm sorry, I meant I just could install Garden to Linux Mint, but not work. It is still not solved yet. I'm working on Fortress instead of using Garden.
Asked by fonawork on 2022-04-03 23:16:33 UTC
Did Fortress work?
Asked by kakcalu13 on 2022-04-05 07:22:36 UTC
