How can i apply same model plugin to different models?
Hi, im new in Gazebo. I've tried to write a model plugin that changes pose of attached model. My plugin;
#include <functional>
#include <gazebo/gazebo.hh>
#include <ignition/math/Vector3.hh>
#include <ros/ros.h>
double old_time =0;
bool up =false;
namespace gazebo
class Reds : public ModelPlugin
/// \brief Pointer to the world
public: physics::WorldPtr world;
public: void Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf)
this->model = _parent;
// simulation iteration.
std::bind(&Reds::OnUpdate, this));
ROS_WARN("Loaded Reds Plugin with parent...%s", this->model->GetName().c_str());
public: void OnUpdate()
if(ros::Time::now().toSec() - old_time>=4){
if(!up){
this->model->SetWorldPose(ignition::math::Pose3d(0,0,10,0,0,0));
up=true;
else{
this->model->SetWorldPose(ignition::math::Pose3d(0,0,0,0,0,0));
up=false;
old_time = ros::Time::now().toSec();
// Pointer to the model
GZ_REGISTER_MODEL_PLUGIN(Reds)
and my world file is like this;
<?xml version="1.0"?>
<sdf version="1.4">
<world name="default">
<name>"stop_light_1"</name>
<pose>0 2 0 0 0 0</pose>
<uri>model://traffic_light_red</uri>
<plugin name="Reds" filename="libReds.so">
<name>"stop_light_2"</name>
</world>
When i launch the world i can see gazebo register plugins,
but it only effect first one. Ive tried to write another plugin wich is same as Reds plugin and add this new plugin to it. It didn't work. How can i apply same model plugin to different models?
Asked by robotdeha on 2022-04-24 04:06:53 UTC
