Which Gazebo versions Supported for Ubuntu 22.04(Jammy)
asked 2022-05-03 14:46:44 -0500
I am using Ubuntu 22.04. Because laptop has AMD RX5600m GPU therefore other Ubuntu versions throws many error for GPU.
I've tried installing gazebo (gazebo9 - gazebo11) but I am getting the below mentioned error. Maybe Gazebo9 or 11 not supported Jammy.
ERROR is:
Reading package lists... Done Building dependency tree... Done Reading state information... Done
N: Ignoring file 'gazebo-stable.listwget' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: Unable to locate package gazebo11
answered 2022-05-06 12:57:13 -0500
chapulina gravatar image
You can see all the supported platforms for Gazebo classic here:
https://classic.gazebosim.org/#status
Gazebo 9 is only officially supported up to Ubuntu Bionic, and Gazebo 11 only up to Ubuntu Focal.
You'll notice that Gazebo 11 is an official package on Ubuntu Jammy though:
https://packages.ubuntu.com/cs/jammy/...
Just do
sudo apt install gazebo
As with any official package, that won't be getting new features nor minor bugfixes.
You may also be able to compile Gazebo 11 from source on Jammy, but we're not actively maintaining that. If something is broken, we'll review pull requests from the community though.
For completeness, I'll mention that we also have Gazebo Fortress upstream on Ubuntu Jammy, just do:
sudo apt install libignition-gazebo-dev ignition-tools
Unlike Gazebo 11, Fortress is officially supported on Jammy and we release binaries with new features and bugfixes into http://packages.osrfoundation.org/ and http://packages.ros.org/.
This solution with sudo apt install gazebodoesn't work for me (https://answers.gazebosim.org/questio...) because of unmet dependencies: gazebo : Depends: libgazebo11 (= 11.10.2+dfsg-1) but 11.12.0-1~focal is to be installed. Should I try to build it from source?
ljaniec gravatar imageljaniec ( 2022-11-14 01:51:04 -0500 )edit
answered 2022-05-14 04:00:03 -0500
zHarunz gravatar image
Thank you, now "sudo apt install gazebo" usable.
Asked: 2022-05-03 14:46:44 -0500
Seen: 2,022 times
Last updated: May 14 '22
