Robot collision and visuals not loaded/shown properly
asked 2022-05-04 05:45:48 -0500
NotARobot gravatar image
Greetings. I try to load a Universal Robots UR10 via it's URDF file into Gazebo. The robot spawner does allegedly spawn the robot correctly. Nevertheless, nether the robots visuals (.dae) nor its collisions (.stl) are shown. I can verify that the robot is in the world with all its links and joints according to the 'World' tab, also if the inertia is visualized, the inertia is properly displayed (as seen in the images).
image description
RViz does visualize properly.
image description
image description
Due to it's complexity I tried to load just the base of the robot for a minimal example.
<?xml version="1.0"?>
<robot name="test_ur10" xmlns:xacro="http://wiki.ros.org/xacro">
<link name="world">
    <origin xyz="0 0 1" rpy="0 0 0"/>
<link name="base">
    <visual>
            <mesh filename="package://models/meshes/ur10/visual/base.dae" scale="0.001 0.001 0.001"/>
        <color rgba="${255/255} ${108/255} ${10/255} 1.0"/>
    <collision>
            <box size="1 1 1"/>
        <mass value="1"/>
        <inertia ixx="1" ixy="0.0" ixz="0.0"
                 iyy="1" iyz="0.0"
                 izz="1" />
<joint name="wold_joint" type="fixed">
    <parent link="world"/>
    <child link="base"/>
</robot>
But even here the visual is not displayed, just the collision (in order to confirm a simple collision loads with the visual).
image description
Note: The meshes are originally from Universal Robots and at least the .stl are checked by me in Fusion 360.
Is there a solution to my problem? Am I missing something?
answered 2022-08-03 02:37:45 -0500
Even if the path for the meshes is defined as 'package' somewhere in the process it is changed to 'model' and subsequently Gazebo searches its model directory (.gazebo/models). My workaround is the creation of a soft link between my meshes within my ROS Package and the model directory (ln -s [Source_File_Path] [Symbolic_Link_Path]).
It is not elegant but it works - I hope this helps others.
Asked: 2022-05-04 05:45:48 -0500
Seen: 72 times
Last updated: Aug 03 '22
