Problems when using lidar and camera on the same robot on Ignition
Hi, I am trying to create a simple two-wheeled robot in Ignition using a xacro description file. I intend to spawn this robot with a lidar and a camera sensor and for both of each I use the plugin named "ignition::gazebo::systems::Sensors". The sensors are added to the robot xacro via macros, which contain the following snipets of code:
<gazebo reference="cam_front">
<sensor name='${name}' type='camera'>
<pose>${body_dim_x/2} 0 ${body_dim_z/2} 0 0 0</pose>
<update_rate>5</update_rate>
<topic>${name}/camera_image</topic>
<!-- <horizontal_fov>1.047</horizontal_fov> -->
<!-- <width>320</width>
<height>240</height> -->
<width>640</width>
<height>420</height>
<!-- <format>B8G8R8</format> -->
<!-- <clip>
<far>100</far>
</clip> -->
<plugin filename="libignition-gazebo-camera-video-recorder-system.so" name="ignition::gazebo::systems::CameraVideoRecorder">
<gazebo reference="base_lidar">
<sensor name="${name}" type='gpu_lidar'>
<pose>0 0 ${body_height*0.6} 0 0 0</pose>
<!-- <pose>0 0 1.0 0 0 0</pose> -->
<topic>${name}/lidar</topic>
<update_rate>10</update_rate>
<ray>
<scan>
<horizontal>
<!-- <samples>90</samples> -->
<samples>10</samples>
<resolution>1</resolution>
<min_angle>${-radians(20)}</min_angle>
<max_angle>${radians(20)}</max_angle>
</horizontal>
<vertical>
<min_angle>${-radians(10)}</min_angle>
<max_angle>${radians(10)}</max_angle>
</vertical>
</scan>
<range>
<!-- <min>0.08</min> -->
<min>0.1</min>
<max>2.0</max>
<resolution>0.01</resolution>
</range>
</ray>
<plugin filename="libignition-gazebo-sensors-system.so" name="ignition::gazebo::systems::Sensors">
<render_engine>ogre</render_engine>
When I try to spawn the robot with each sensor separately, they work correctly, as it can be seen in the image below.
However when both of the sensors are included in the xacro, the simulator crashes and displays the following error:
Could someone help me find what is causing this issue?
Gratefully, Lucas
Asked by Lucas_bmp on 2022-05-04 13:42:53 UTC
have you tried moving the plugin out of the sensors xacro files in to the Robot xacro files for me this is working fine. Cleaner and future proof would be to call the plugin from the world file like https://github.com/gazebosim/gz-sim/blob/668b757c962e23f33c826487e4f725b3fd4486c5/tutorials/server_config.md?plain=1#L284 but I'm also currently strugeling on this step but as long as you have only one robot in the simulation this will work.
Asked by Torben on 2023-05-04 06:15:54 UTC
