high CPU usage when using ros_ign_bridge
I am looking into using gazebo ignition on a new ROS2 project and am building up an example that is a basic differential drive robot with a lidar on top. The lidar is putting out a laserscan message with only 100 samples. Because this is a ROS2 project, I need to get that data over to my (currently non-existent) ROS2 nodes so I am using rosignbridge to transfer the data. This seems to work fine with cmd_vel messages coming from ROS2 but the lidarscan messages are causing my computer to go nuts with all 16 cores using about 80% of their available CPU cycles if I have a bridge for that topic.
Here is how I am setting up the node in my launch file:
Node(
package='ros_ign_bridge',
executable='parameter_bridge',
arguments=['/lidar@sensor_msgs/msg/LaserScan@ignition.msgs.LaserScan']
Here is my 'lidar', which is located within my chassis link. It is basically a copy-paste from something I found on the web:
<sensor name='gpu_lidar' type='gpu_lidar'>"
<pose relative_to='lidar_frame'>0 0 0 0 0 0</pose>
<topic>lidar</topic>
<update_rate>10</update_rate>
<ray>
<scan>
<horizontal>
<samples>100</samples>
<resolution>1</resolution>
<min_angle>-1.396263</min_angle>
<max_angle>1.396263</max_angle>
</horizontal>
<vertical>
<samples>1</samples>
<resolution>0.01</resolution>
<min_angle>0</min_angle>
<max_angle>0</max_angle>
</vertical>
</scan>
<range>
<min>0.08</min>
<max>10.0</max>
</range>
</ray>
If I just comment out the rosignbridge node in my launch file then the CPU usage is maybe 10%. Is there anything that I can do to make it not consume almost everything my computer has to offer?
I'm pretty sure that I am using the Fortress version of ignition. I'm not sure how to check. Gazebo is saying ignition gazebo 6.9.0
Asked by raefsel on 2022-05-05 19:11:04 UTC
