How to use libgazebo_ros_p3d ?
I'm using ros2 foxy on ubuntu 20.04 with Gazebo multi-robot simulator, version 11.10.2 I'm trying to simulate a robot using the plugin libgazeborosp3d as I need to have the position over the time published on a topic "odom".
My code work fine with and without the plugin (the simulation starts and I can control my robot), I even have other plugins used (IMU and diff-drive). However the plugins seem to not work (nothing is published) and i get the error :
[gazebo-4] [ERROR] [1652081431.073520636] [p3d.libgazebo_ros_p3d]: body_name: base_link does not exist
here is my code simplified :
<robot name="my_robot">
  <!-- link used to allow base_link to have an inertia-->
  <link name="dummy">
  <!-- Robot Base_link -->
  <link name="base_link">
    <visual>
      <origin rpy="0 0 0" xyz="0.24765 0 0.16755"/>
        <box size="0.4953 0.5505 0.3351"/>
      <material name="Cyan">
        <color rgba="0 1.0 1.0 1.0"/>
    <collision>
        <box size="0.4953 0.349 0.3351"/>
  <gazebo>
    <plugin name="libgazebo_ros_p3d" filename="libgazebo_ros_p3d.so">
        <ros>
            <namespace>p3d</namespace>
            <remapping>odom:=odom</remapping>
            </ros>
            <frame_name>map</frame_name>
            <body_name>base_link</body_name>
            <update_rate>200.0</update_rate>
            <gaussian_noise>0.01</gaussian_noise>
      <joint name="dummy_joint" type="fixed">
        <parent link="dummy"/>
        <child link="base_link"/>
    </robot>
BTW I have Inertial tags but id didn't paste them here to make the code a little bit easier to read, though i'm far from being an expert so if you belive I should add them i will !
Is there a way to make this plugin work with my code ? Or is there another way to publish odom as position over the time ? I can't seem to find much documentation on this subject sadly.
Thank you to anyone who took the time to read my question
Asked by Bastian2909 on 2022-05-09 03:02:48 UTC
