Tricycle drive plugin: Impossible to control linear and angular speed at the same time
I believe there is a bug in the tricycle plugin. I'm testing the ROS2 Galactic version of the plugin: https://github.com/ros-simulation/gazebo_ros_pkgs/blob/galactic/gazebo_plugins/src/gazebo_ros_tricycle_drive.cpp which I believe is quite similar to the ROS1 version. For this test, I'm using the demo of the Tricycle plugin:
I recorded a video of the behavior which you can see in the following Youtube video:
As you can see in the video, it is impossible to control a tricycle robot in linear speed and angular position at the same time.
Any ideas of why is this happening?
Best,
Asked by andrestoga on 2022-05-10 20:59:10 UTC
you can try ros2_control instead gazebo_control config, Check it out of here: https://github.com/ros-controls/ros2_controllers/blob/humble/tricycle_controller/config/tricycle_drive_controller.yaml
Asked by imphvc on 2023-07-20 21:40:50 UTC
