why am I not able to use the argument value of a xacro under a gazebo tag?
I'm just showing the relevant parts..
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="xyz">
<xacro:arg name="robot_names" default="robot_1"/>
<gazebo>
    <plugin name="object_controller" filename="libgazebo_ros_planar_move.so">
      <robotNamespace><remapping>/tf:=tf</remapping>  </robotNamespace>
      <ros>    <remapping>/tf:=tf</remapping>    </ros>
      <!-- Set control loop update rate -->
      <odometryRate>100</odometryRate>
      <!-- Set odom publish rate -->
      <publish_rate>100</publish_rate>
      <!-- Set if odom required -->
      <publish_odom>true</publish_odom>
      <publish_odom_tf>true</publish_odom_tf>
      <!-- Frame IDs -->
      <odometry_frame>${robot_names}</odometry_frame>
      <robot_base_frame>${robot_names}base_link</robot_base_frame>
      <!-- Set odom covariance -->
      <covariance_x>0.0001</covariance_x>
      <covariance_y>0.0001</covariance_y>
      <covariance_yaw>0.0001</covariance_yaw>
</robot>
Asked by pmuthu2s on 2022-05-16 04:19:54 UTC
For an argument, you need to call it using:
${arg robot_names}
Asked by joe28965 on 2022-05-25 04:50:36 UTC
