vtol aerodynamic unit and cp, area
<!-- taken from the lift curve figure -->
<!-- alpha_0 is 5 degrees -->
<a0>0.08727</a0>
<!-- alpha_stall is 19.3 degrees -->
<alpha_stall>0.3368</alpha_stall>
<!-- slope of the lift curve to the left of the stall angle -->
<cla>5.418</cla>
<!-- slope of the lift curve to the right of the stall angle -->
<cla_stall>-2.1419</cla_stall>
<!-- below are just random values in this example -->
<cda>0.0</cda>
<cda_stall>0.0</cda_stall>
<cma>0.0</cma>
<cma_stall>0.0</cma_stall>
<area>3</area>
<fluid_density>1.2041</fluid_density>
<forward>-1 0 0</forward>
<upward>0 -1 0</upward>
<cp>0 0 1</cp>
<link_name>lifting_surface_link</link_name>
<radial_symmetry>false</radial_symmetry>
- What is the unit of area here?
- I'm curious as to which area exactly represents the area. If you have a formula please let me know
- Is it correct that the parameter value of cp represents x y z and What is the unit of cp here?
Asked by bbaring on 2022-05-22 18:56:24 UTC
