Using an IMU Sensor without ros?
asked 2022-05-25 14:59:38 -0500
kgz gravatar image
Ive tried looking through various discussions/docs, etc to find an example of attaching an IMU to a model in Gazebo 11 without using ROS to no avail. I believe this should be possible, but Ive not been able to do it in a way where the appropriate topic shows up in the list of topics.
Here is one example of an attempt, based off a post in these forums:
<?xml version='1.0'?>
<sdf version ='1.5'>
  <model name ='box2'>
    <pose>1 2 0 0 0 0</pose>
    <link name ='link'>
      <pose>0 0 .5 0 0 0</pose>
      <collision name ='collision'>
          <box><size>1 1 1</size></box>
      <visual name ='visual'>
   <gazebo reference="link">
        <sensor name="imu" type="imu">
         <update_rate>1000</update_rate>
         <topic>__default_topic__</topic>
         <imu>
          <noise>
           <type>gaussian</type>
            <rate>
             <mean>0.0</mean>
             <stddev>2e-4</stddev>
             <bias_mean>0.0000075</bias_mean>
             <bias_stddev>0.0000008</bias_stddev>
            </rate>
            <accel>
             <mean>0.0</mean>
             <stddev>1.7e-2</stddev>
             <bias_mean>0.1</bias_mean>
             <bias_stddev>0.001</bias_stddev>
            </accel>
          </noise>
         </imu>
Does anyone know if what I am trying to do is actually possible / have an example of using an IMU without any reliance on ROS?
answered 2022-05-25 15:48:04 -0500
kgz gravatar image
So in typical fashion, after not being able to figure it out for hours, I almost immediately figured it out right after asking for help.
To fix this issue, you just need to embed sensor inside the actual link, as follows:
    <link name ='link'>
         <imu>
          <noise>
            <rate>
             <mean>0.0</mean>
            </rate>
            <accel>
             <mean>0.0</mean>
            </accel>
          </noise>
         </imu>
Asked: 2022-05-25 14:59:38 -0500
Seen: 34 times
Last updated: May 25 '22
