waitForService: Service /gazebo/set_physics_properties has not been advertised, waiting... (AWS)
I have containerized both the robotic application and simulation application and then I have runned them both with the following commands:
$ docker run -it -e DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix/ -u robomaker -e ROBOMAKERGAZEBOMASTERURI=http://localhost:5555 -e ROBOMAKERROSMASTERURI=http://localhost:11311 \robomaker-helloworld-robot-app:latest roslaunch helloworldrobot rotate.launch
and
$ export DISPLAY=:0
$ xhost +
$ docker run -it -e DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix/ -u robomaker -e ROBOMAKERGAZEBOMASTERURI=http://localhost:5555 -e ROBOMAKERROSMASTERURI=http://localhost:11311 \robomaker-helloworld-sim-app:latest roslaunch helloworldsimulation empty_world.launch
for the robot app and sim app respectively. After this, I entered inside the container of the sim app and runned the following commands:
$ source /opt/ros/melodic/setup.bash
$ source /usr/share/gazebo-9/setup.sh
$ rosrun gazebo_ros gzclient
The Gazebo GUI opens inside the Virtual Desktop (I'm using AWS RoboMaker) but the robot stands still instead rotating around the z axis with angular velocity 0.1 rad/s (as it is supposed to do). I obtain the following message:
[ INFO] [1654096062.809673647]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1654096062.821667855]: waitForService: Service /gazebo/setphysicsproperties has not been advertised, waiting...
Do you know what could be the cause of this problem?
Asked by MatteoSartoni on 2022-06-02 05:16:16 UTC
