Add urdf to world using a python script while gazebo is running (/world/my_world/create service + EntityFactory message)
Hi
I'm trying to add a cube to my gazebo scene programmatically while gazebo is running.
I found that ignition has the service /world/my_world/create service that accepts new urdf/sdf files.
However, I'm struggling to send the correct request in python, since I don't know how to install the ignition messages on my system and how the request has to be structured.
Here is a tutorial in C++: https://gazebosim.org/api/gazebo/6.9/entity_creation.html
Here is the terminal call which spawns a sphere in the world:
ign service -s /world/empty/create \
--reqtype ignition.msgs.EntityFactory \
--reptype ignition.msgs.Boolean \
--timeout 300 \
--req 'sdf: '\
'"<?xml version=\"1.0\" ?>'\
'<sdf version=\"1.6\">'\
'<model name=\"spawned_model\">'\
'<link name=\"link\">'\
'<visual name=\"visual\">'\
'<geometry><sphere><radius>1.0</radius></sphere></geometry>'\
'</visual>'\
'<collision name=\"visual\">'\
'</collision>'\
'</link>'\
'</model>'\
'</sdf>" '\
'pose: {position: {z: 10}} '\
'name: "new_name" '\
'allow_renaming: true'
My plan:
- Install ignition messages (But how?)
- Setup ign bridge to forward message /world/my_world/create from ign to ROS2 (in launch file)
# rosignbridge (clock -> ROS 2) Node( package="rosignbridge", executable="parameterbridge", output="log", arguments=[ "/world/myworld/create@ignition.msgs.EntityFactory@ignition.msgs.EntityFactory", "--ros-args", "--log-level", loglevel, ], parameters=[{"usesimtime": usesim_time}], ),
- Use python script to spawn cube.urdf in gazebo world
Importing the library:
from ignition-messages import EntityFactory # What is the correct syntax/name of the library?
Publishing the message: How do I construct a valid message?
my_sdf = """
<?xml version="1.0" ?>
<sdf version='1.7'>
<model name='sphere'>
<link name='link'>
<pose>0 0 0.5 0 0 0</pose>
<visual name='visual'>
<geometry><sphere><radius>1</radius></sphere></geometry>
<collision name='collision'>
</sdf>"""
publisher = self.create_publisher(EntityFactory, '/world/my_world/create', 1)
msg = EntityFactory()
while rclpy.ok():
msg.data = 'Hello World: ' # How do I construct a valid message?
msg.model = my_sdf
publisher.publish(msg)
This is the message definition: https://github.com/gazebosim/gz-msgs/blob/ign-msgs8/proto/ignition/msgs/entity_factory.proto
Thanks in advance for your help.
Asked by marc-marc on 2022-06-02 06:35:25 UTC
I legit had no idea this exists! I have no idea how this works. I gotta test it ASAP! Thanks for the link!
Anyway I use python to load robot by using import os
So, I use like this
first_part = "ign service -s /world/free_world/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 300 --req 'sdf_filename:'\'\""
second_part = model_name + ".sdf\" pose: {position: { x: 0.05, y"
third_part = ": " + y + ", z: " + z + "}}\' &"
add_model = first_part + second_part + third_part
os.system(add_model)
In another word, I used command line exact as this:
ign service -s /world/free_world/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 300 --req 'sdf_filename:''"models/sdf/freenove_smart_car.sdf" pose: {position: { x: 0.05, y: 4.12, z: 0.325}}' &
Which would work in your command line as long as you change the free_world to your world's name and files location/name.
Basically, I use command line within python to get all data or controls from Gazebo.
Not sure how much this fits your needs.
P.S.
I never had any luck on this one, but you can try this one. This is still under heavy development, I think.
I know this is not the answer but I hope this suggestion helps.
Asked by kakcalu13 on 2022-06-02 12:35:54 UTC
Thanks for your code. It works like a charm.
I was struggling a lot with the single quotes and escaping characters in the --req part.
Next I want to move or set the pose of the spawned objects in the scene. I assume there is another service for this:
/world/ign_moveit2_follow_target_world/control
/world/ign_moveit2_follow_target_world/control/state
/world/ign_moveit2_follow_target_world/create
If you already have a working command, I would appreciate your insights. Best, Marc
Asked by marc-marc on 2022-06-03 04:47:11 UTC
Looks like you got it working!
This is one of ways to run command using multiple special characters.
As for the single or double quotes and if you don't want to do this way..you can use \" so for example
ign service -s /world/free_world/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 300 --req \'sdf_filename:'\'\"models/sdf/freenove_smart_car.sd\f" pose: {position: { x: 0.05, y: 4.12, z: 0.325}}' &
Asked by kakcalu13 on 2022-06-03 06:44:36 UTC
As for the move the pose (or maybe set of pose?), you can use this example: https://github.com/gazebosim/gz-sim/blob/ign-gazebo6/examples/worlds/shapes.sdf#L6
Asked by kakcalu13 on 2022-06-03 06:45:50 UTC
The setting of the pose works with your command. However calling this command multiple times in a for-loop to set the position of items on a conveyor belt is really slow. Do you have an idea on how to solve high-frequency position updates? I opened a new question: https://answers.gazebosim.org/question/28260/set-pose-of-model-programmatically-with-higher-frequency-using-ign-transport/
Asked by marc-marc on 2022-06-22 09:04:45 UTC
Here is the python code to set the pose of any object using a cli command:
first_part = "ign service -s /world/my_world/set_pose --reqtype ignition.msgs.Pose --reptype ignition.msgs.Boolean --timeout 300 --req 'name: \""
model_name = 'spawned_model'
second_part = model_name + "\", position: {z: 5.0}'"
system(first_part+second_part)
Asked by marc-marc on 2022-06-03 05:18:09 UTC
