Simulation application stops subscribing to topics when I run gzclient
I am working with ROS, Docker and Gazebo. In my ROS environment I have a robotic application and a simulation one, from which I have built two docker images.
I run the with the following commands:
$ docker run -it -e DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix/ -u robomaker -e ROBOMAKERGAZEBOMASTERURI=http://localhost:5555 -e ROBOMAKERROSMASTERURI=http://localhost:11311 \robomaker-helloworld-robot-app:latest roslaunch helloworldrobot rotate.launch
and
$ export DISPLAY=:0
$ xhost +
$ docker run -it -v /tmp/.X11-unix/:/tmp/.X11-unix/ -u robomaker -e ROBOMAKERGAZEBOMASTERURI=http://localhost:5555 -e ROBOMAKERROSMASTERURI=http://localhost:11311 \robomaker-helloworld-sim-app:latest roslaunch helloworldsimulation empty_world.launch
for the robotapp and the simapp respectively. If I go inside the simapp image, after all the required sourcing, and run the command
$ rostopic list
I get the following output
$ /camera/parameter_descriptions
/camera/parameter_updates
/camera/rgb/camera_info
/camera/rgb/image_raw
/clock
/cmd_vel
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/setlinkstate
/gazebo/setmodelstate
/imu
/joint_states
/odom
/rosout
/rosout_agg
/scan
/tf
The problem is that, when I run the
$ rosrun gazebo_ros gzclient
command from the simapp image, it spans the robot inside Gazebo but it stays still (instead doing the task described in the robotapp) and, if I close the gzclient and I look again to the topics inside the image, I get only these:
$/clock
/joint_states
/rosout
/rosout_agg
Do you know what could be the source of this error?
Asked by MatteoSartoni on 2022-06-05 09:20:28 UTC
