[gazebo_gui-2] process has died [pid 19525, exit code 139]
Hello, I am a student researcher doing research on drone trajectory planning and I need to run a few preliminary simulations to capture data; Keep in mind I am very new to ROS and Gazebo. I am attempting to run a launch file, but I get errors for the default models i.e. sun, and ground_plane. I am using Gazebo7 running on UBUNTU 16.04.
[ INFO] [1654638003.083795479]: Finished loading Gazebo ROS API Plugin.
[Msg] Waiting for master.
[ INFO] [1654638003.084449933]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[Msg] Publicized address: 128.123.232.124
[ INFO] [1654638003.140000140]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1654638003.140639292]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[Wrn] [ModelDatabase.cc:339] Getting models from[http://gazebosim.org/models/]. This may take a few seconds.
[Err] [ModelDatabase.cc:234] No <database> tag in the model database database.config found here[http://gazebosim.org/models/]
[Err] [ModelDatabase.cc:293] Unable to download model manifests
[Err] [ModelDatabase.cc:413] Unable to download model[model://sun]
[Err] [SystemPaths.c``c:410] File or path does not exist[""]
Error [parser.cc:581] Unable to find uri[model://sun]
[Err] [ModelDatabase.cc:413] Unable to download model[model://ground_plane]
[Err] [SystemPaths.cc:410] File or path does not exist[""]
Error [parser.cc:581] Unable to find uri[model://ground_plane]
[ INFO] [1654638004.288018695]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1654638004.298362534]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1654638004.446922234, 0.078000000]: Physics dynamic reconfigure ready.
[ INFO] [1654638004.458115388]: Physics dynamic reconfigure ready.
[gazebo_gui-2] process has died [pid 19525, exit code 139, cmd /opt/ros/kinetic/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/maelab/.ros/log/d8bf38fc-e6a8-11ec-ad7b-0007e90f864b/gazebo_gui-2.log].
log file: /home/maelab/.ros/log/d8bf38fc-e6a8-11ec-ad7b-0007e90f864b/gazebo_gui-2*.log
Asked by coraspe on 2022-06-07 16:56:51 UTC
